What's she worth?
Nearing the end of my project, came across another one and am thinking of bailing out. What do you think she's worth?
'84 C/10 SWB 2WD Was a stepside has a rough fleetside bed on it from a 73-75ish? Cab has had corners done and not such a swell job done on the driver's side floor pan. What i've got done so far: 2000 vortec 350 rebuilt w/out overbore. New nodular eagle crank professionally balanced, with polished edelbrock performer. Also a 1406 edelbrock performer carb. Holley Red fuel pump with regulator mounted on firewall. Also has a serpentine setup installed as well as a flowkooler waterpump. Polished aluminum front cover and a "Dave's Small Body HEI" conversion with accel coil. Also has Taylor wires and Bosch 4+ platinum plugs. Hedman HTD shorty headers for a caprice (fit beautifully) and a flowmaster 3" into two 2 1/2" "Y" with a 3 inch catalytic converter and series 50 flowmaster. Up front is a spal electric fan with thermostat on/off relay. And a Griffin aluminum radiator. topping off the engine is an edelbrock elite open element air cleaner. The tranny is a used GM replacement 700r4. Not sure of the miles on the tranny but assumed to be the heavy duty version as it came of an old Illinois Highway Patrol vehicle. New parts on the truck asside from the above Two new inner fenders. New headlight bezels/headlights, new gas tank, new poly body mounts, new shocks, new breaks up front, and brand new Dayton Timberline LT 31.5 X 10 tires on solid aluminum wheels 15X10 other work done to the truck includes 99% of the frame being stripped and coated with por15 I can keep this for a daily driver while i work on this new project or i can send it off to someone who can finish it off with some body work and paint The only thing not finished is the exhaust, headers are installed and got a quote from the muffler shop of 180 to install pipe from the headers through the Y and then through the CAT and series 50 flowmaster. lemme know what you guys think she's worth Keith Grant
true power comes from above!!! 1984 C/10 2wd SWB. Last edited by all4gss; 11-30-2003 at 09:01 PM. |
Project92 SWB stepside
Without pics I would not even begin to say!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
well i'm finally home now, i'll go get some pics of her as she sits and send some mid-way pics along too.
I always forget how you tag an image on the board? thanks. keith
true power comes from above!!! 1984 C/10 2wd SWB. |
