07-05-2019, 09:54 AM | #1 |
1968 c10 w 5.7 does HEI fit
Hey everyone,
I have a 1968 c10 with a 350. I would like to purchase a curved HEI DUI (Davis Unified) distributor called a crossfire from Performance Distributor. Does anyone know if this larger cap design will fit with a factory firewall? https://performancedistributors.com/product/streetstrip-dui-distributor-w-cross-fire-cap/ Thank you for the help, John Posted via Mobile Device |
07-05-2019, 09:59 AM | #2 | ||
"I ain't nobody, dork."
Re: 1968 c10 w 5.7 does HEI fit
Don't see why it wouldn't. It's one of the best upgrades you can do to your rig. Some cats have had firewall clearance issues from the engine being mounted too far back. But that usually from the engine being placed in the wrong mounting spots.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-05-2019, 10:04 AM | #3 |
Should fit, just remember to replace the resister wire with a new wire,you can buy one or make your own
07-05-2019, 12:43 PM | #4 |
Awesome. I just wanted to make sure to try to avoid needing to create more clearance.
Good point on the resistor wire. I’ll be running a new line. Thanks for the advice guys! Posted via Mobile Device |
07-05-2019, 01:21 PM | #5 |
Easy to measure!
The hei is 1 1/2 inches bigger in diameter. You need a minimum of 3/4 inch for it to fit tight to the firewall. Anything more than that and you’re good. |
07-05-2019, 01:39 PM | #6 |
1000's of these swaps done without having to make any extra clearance!!!
07-05-2019, 03:12 PM | #7 |
Post Whore
Worth a thousand words.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-05-2019, 10:08 PM | #8 |
I don't have the crossfire cap, but i have that same distributor in my 68 with a 350. Only real problem i had was that the screws that hold the cap on are difficult to get to. Other than that no problem.
