Old 07-06-2019, 10:27 AM   #1
hooverfish
hooverfish's Avatar
Transmission leaking, need help to diagnose , overnight,
Trans leaking, seems to be only dripping from the flywheel dust cover.
I drained the pan a couple weeks ago and put in 2.5 quarts fresh fluid
which is amount that I took out. And now it's leaking, about an ounce overnight.
Cannot see any leaks around speedo, dipstick, etc. It's all coming from bottom of dust cover.
This is a 75,000 mile truck (72 350/350) and the trans shifts/drives perfect.
I searched a lot of old threads but couldn't find this exact problem. Any suggestions or ideas appreciated.
Larry
84 Chevy SWB, "Roy", dark blue orig paint, 6 cyl auto, PS, 88,000 miles.
72 Highlander LWB "Olive" med olive over lt yellow, air, 77,000 miles (sold)
"It's a sorry man who can't find his wife a good job"
hooverfish is offline   Reply With Quote
Old 07-06-2019, 10:39 AM   #2
Hammond68
Re: Transmission leaking, need help to diagnose , overnight,
Front seal.
1972 c10 cheyenne.
383 stroker 10-1
280 magnum comp cams
700r4 tranny.
Hammond68 is offline   Reply With Quote
Old 07-06-2019, 10:52 AM   #3
weim55
Leaks can be tricky and elusive to find the source. For the automatic transmissions in our trucks the number one source for an overnight leak is the dipstick tube O-ring. As the truck sits overnight the level in the transmission pan rises up past the level of that O-ring. Not uncommon for that leak to make its way to the transmission torque converter cover and drip to the floor from there. While your leak could certainly be the torque converter seal it’s not nearly as common. As simple and cheap as that dipstick O-ring seal is to replace I would do that first and see if that cures the problem. If it doesn’t I would pull the transmission and just do a complete re-seal of all the external seals and be done with it.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 07-06-2019, 10:53 AM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
weim55 beat me to it. Good post. We used to see loads of front seal leaks and these usually leak pretty badly while on the rack engine running. If this is it, obviously it needs to come out for a reseal job minimum. If it's got 75K on it I would seriously consider a "rebuild".
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 07-06-2019, 10:54 AM   #5
jocko
jocko's Avatar
I'd have to agree that's most likely source. One thing to elminate is to look at your trans cooler lines and see if one is perhaps cracked or a fitting loose. Depending where the issue is, it "could" cause it to look like drips from the pan/tc cover (I had a trans line coupler in my trans cooling line almost even with the dust cover and some of the fluid was leaking onto the dust cover and running down to the center, making it appear to be coming from inside the dust cover at first glance). Just a thought, highly unlikely if your trans cooler lines are untouched from original config though, unless there is a pinhole/small crack etc. Anyway, recommend just look at them, but they are not likely the problem, unfortunately.
Old 07-06-2019, 12:30 PM   #6
RodnRudy
RodnRudy's Avatar
Get it up on jack stands and remove the dust cover. Then clean everything with brake cleaner and run it in gear for a while, shut it off and wait for the leak to appear. Like others have said, ATF can track to the front of the trans even though it is seeping out some where else.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 07-06-2019, 01:07 PM   #7
Wrenchbender Ret
Check around the selector shaft. The seal in there is a very common leak.
I would look & watch very closely before I snatched the trans out.
Wrenchbender Ret is online now   Reply With Quote
Old 07-07-2019, 10:17 AM   #8
hooverfish
hooverfish's Avatar
I really appreciate all the replies. I'm going to wait a couple days and see what I can find. Check out all the suggestions. I will post an update when I know something. Hate this because I'm sure I did it with the trans fluid, self inflicted, I should know better.
Larry
Old 07-07-2019, 12:23 PM   #9
Grumpy old man
Grumpy old man's Avatar
Fastest easiest way to find any oil/ trans fluid leak .
https://www.youtube.com/watch?v=2wCtBVlkujE
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 07-19-2019, 12:11 PM   #10
hooverfish
hooverfish's Avatar
My neighbor told me about a transmission expert so I took it to him. Nicest guy you'd ever want to meet, 76 years old, been rebuilding transmissions since 1967, still works every day in his one bay garage. He confirmed it was the front seal, pulled the transmission, and recommended complete overhaul while I had it out. Said he was surprised it even pulled in reverse due to condition of a pump or something. And showed me the seals and O-rings that were all hard as rocks, filter and pan full of the coating stuff from clutches.
He did a great job, cleaned the trans case in this oven type device, all new parts, seals, guaranteed, etc. He treated it like he owned it, did all the little stuff, cleaning and such. I'm convinced he could rebuild one of these blindfolded. Charged me $850 which I think is very good.
Thanks again to everyone for your help and comments.
Larry
Old 07-20-2019, 12:18 PM   #11
jocko
jocko's Avatar
Great news. And great price. I used to have a friend like that, who was really a friend of my Dad's - so he treated me like family, when I was a kid. He had a racing trans shop and was always happy to lend a hand - usually out of his own small home garage with the double 55-gal drum wood stove for those cold NW Indiana winters AFTER his long work days, and usually for free. In fact, I seem to recall he just "gave" me a rear end for my 57 chev when I did stupid kid stuff and destroyed my spider gears... (but was at least able to drive home in reverse late, very late at night...) I learned a lot from him, most of which had nothing to do with cars and trucks. Those folks are still around, just not as plentiful. And I'd imagine many of "those" folks reside on this board
Old 07-21-2019, 09:01 AM   #12
hooverfish
hooverfish's Avatar
Thank you for sharing those memories. Those old fellas are local treasures.
Larry
Old 07-21-2019, 12:43 PM   #13
Barnfind46
Barnfind46's Avatar
I agree with Jocko, I think a lot of those guys are on here in our little community!
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
