67-72 wiper motor ...upgrade?
It's hard to believe, but the last time I posted on this forum was almost 12 years ago and I still have the Longhorn!
After ALL those years of me waffling between ...sell it, keep it, sell it .....KEEP it ...well ...I'm keeping it ![]() Any who ...what are my options for updating the wiper motor. There seems to be only one thread discussing it. Ideas? Tom
1971 Chevy Longhorn |
![]() Join Date: Jan 2001
Re: 67-72 wiper motor ...upgrade?
No ideas, but welcome back.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: Dec 2006
What are the symptoms? I thought mine was toast but it turned out to just be the connection behind the switch came loose. Does it run at all? -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
I think Detroit Speed makes a 5 speed direct replacement for us. Not cheap though if I recall. Around $500-600.
![]() Join Date: Apr 2006
Kirk 72 Blazer CST 4wd highlander 66 Nova |
#6 | |
I found a link for the expensive option. https://www.detroitspeed.com/all-pro...k-121631-group |
The motor still functions but is very slooooooow. It no longer has two speeds.
I use the Newport wipers kit with the intermittent option on all my customers build. very nice product. I have met the inventor/owner at Goodguys car show in Ft Worth, very nice to deal with, and made in America product using all GM components so they can be sourced for replacements.
I have one of the first kits released on my 68, it has been installed for over 9 years, works flawlessly
A C Ward Retired US Army 66 El Camino 67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475 |
#9 | |
Post Whore
![]() Join Date: Feb 2016
On my Burban I tore the linkages apart, cleaned and lubed everything. Replaced the shaft seal and greased the shaft, then reassembled. (The seal made a noticeable difference in speed) It works much better now. A little slow for the first 30 seconds or so but then it works good. I have had to use the high speed on occasion when the rain is heavy. It is my daily driver here in NW Oregon. I haven't found any time yet when high speed wasn't fast enough. But I also haven't experienced any deluges like the ones I experienced back in Virginia years ago.
I had to drive the old ladies Lexus a couple of weeks ago in the rain and I'm so accustomed to the slower speed of the truck's wipers, the Lexus's wipers were freaking me out as they are violently fast. I also installed a intermittent wiper controller from Revolution Electronics. It is great and no where near as expensive as some other options.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Sounds exactly like mine. I'll be watching this thread. I may try lube'n it all up like HO455 did.
Thanks HO455 for the info. I shall try that first.
#13 |
Old member
Factory motor and linkage works great. I added a electric water jug out in the motor area and squirters off a Tahoe back glass to the wiper arms so I get the whole window sprayed.
I also bought the delay feature from twouvakind who is a memeber here he makes the delay switch for our trucks. It's a plug and play deal. Check it out here. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=721854
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#14 |
![]() Join Date: Jun 2017
i have a brand-new in box Detroit speed unit if you want it. can sell for cheaper then new.
#15 |
![]() Join Date: Jan 2013
grndcont,
sent you a PM. |
#16 | |
#17 | |
![]() Join Date: Aug 2012
I did the same thing with my ‘72 Blazer. Stock knob fits right onto switch and looks stock inside. For better spray coverage, I did a similar set up as Andy. I sprayed my arms black so the hose and spray nozzle disappear. It looks and functions great. Mine has the intermittent setting, much needed here in the Pacific NW...lots of light rain conditions. Only complaint I have is the motor seems to be noticeably louder than the stock wiper motor when operating. |
