51 4 link and travel ?
Wanting to add 4 link to the 51, with truck at ride ht. And weight on suspension.what is the least amount of space i need between top of axle tube and bottom of frame? If i notch the frame i can only gain about an inch before the top of pumpkin hits the bead wood.would 3” be doable? That would get me the look i want, and would just allow a 14” shock to work, plan on qa1 coilovers,
#2 | |
Re: 51 4 link and travel ?
