07-08-2019, 05:18 PM | #1 |
Rear qa1 springs
51 truck, sbc th 400, adding 4 link and qa1’s, what weight spring you recommend? Also posted another thread about shock travel, might need a llittle stiff as i think i will be limited to abou 3” of travel down, before frame hits axle tube or rubber stops
07-11-2019, 09:54 AM | #2 |
Re: Rear qa1 springs
I would contact the tech @ Qa1 as your best resource option.
07-11-2019, 11:36 AM | #3 |
Going to goodguys tomorrow, should see some more stuff! Thanks
07-11-2019, 12:09 PM | #4 |
Cool. The Columbus show is awesome! Qa1 should have a booth w/reps for sure.
