Old 07-08-2019, 06:52 PM   #1
muddstir
muddstir's Avatar
Disc brake upgrade options / drop spindles.
I just dug my 71 out of storage, sat 6 years untouched. The entire braking system needs to be replaced but I don't just want to replace it I'd like to upgrade it. All I know is sometimes the spindles can determine what you can do for braking upgrades. ( even if that is right).
I am looking to lower it with drop spindle so I'd like to buy the right ones that will let me to run a better setup. Or is there even a swap that can adapt other better setups to most drop spindles?
Trying to find a good build thread on this with my allotment of time I've got hasn't pan out yet. So anybody know of one ?
Man I hope this made some sense.
muddstir is offline   Reply With Quote
Old 07-09-2019, 11:00 AM   #2
siggyfreud
siggyfreud's Avatar
Re: Disc brake upgrade options / drop spindles.
Most aftermarket disc brake setups would use a modular spindle. CPP makes a set. I believe Wilwood does too, but they're a good bit more expensive.
If you're just wanting to run a factory disc brake kit you can use Belltech's drop spindles as well.
siggyfreud is offline   Reply With Quote
Old 07-10-2019, 02:57 PM   #3
muddstir
muddstir's Avatar
Thanks.
I'm assuming that I can't run a Wilwood setup on cpp spindles.
I did find a build where a guy put a front and rear disc brake setup from wilwood on his truck, and I think he said it Came from az performance (If that's not right I did bookmark the site). It wasn't too bad priced but it wasn't the big brake kit either. Was kinda hoping to find a kit that had a powerbrake booster and master cylinder in it too but I can order those by themself.
I'm still going to do some more looking before I order anything so if you know of any other sites to check out I'd appreciate it. Thanks.
Old 07-10-2019, 03:55 PM   #4
typerr
Originally Posted by muddstir View Post
Thanks.
Most of the drop spindles I've seen are intended to use stock GM calipers. Wilwood makes their own 2 piston version of this caliper. CPP also has a modular spindle which can be used with many different brake kits.
I don't know of anyone that packages the master cylinder with the brakes but there is a ton of options.
Just got done with all this. Western drop spindles, CPP stock type brakes and a 72 master from Autozone. Truck now stops on a dime but bleeding was an ordeal in itself...
typerr is offline   Reply With Quote
Old 07-10-2019, 06:58 PM   #5
siggyfreud
siggyfreud's Avatar
Thanks.
Wilwood makes brake kits for our trucks that work with CPP spindles. So does BAER. I'm currently installing a Baer setup on mine using CPP spindles.
