Old 07-09-2019, 09:10 PM   #1
Red68
Red68's Avatar
V8 engine mount help
I have a 68 with a 327 v8 and a factory 3 speed on the column that I have owned and drove for the last 30 years. I have pulled the sbc to install a 700r4 transmission and a few other upgrades. I am looking for some help with the engine mounts that bolt to the frame, they are in the “back” holes, I believe it originally had a 6 cylinder.
Can I use the current engine stands and move them to the front holes with the same engine? I moved them ahead after I pulled the engine but have not reinstalled the engine yet. Would they be the same? The only thing I can see I need to do is to drill a new hole for the bottom bolt on each side of the front frame cross member.
Thanks for any help.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 07-10-2019, 06:30 PM   #2
RodnRudy
RodnRudy's Avatar
Re: V8 engine mount help
No the six cylinder mounts you have are shaped wrong for the front location. You need to get V8 mounts and mount them to the front holes on the frame and cross member.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 07-10-2019, 08:57 PM   #3
Red68
Red68's Avatar
Thanks appreciate the help.
Old 07-11-2019, 06:16 AM   #4
Katrina/10
Katrina/10's Avatar
That's what I did. At the time I did not know the six and V8 engine brackets were different. It appeared the V8 engine would sit in the six cylinder brackets, and it did. I found that the 700R4 trans would hit the floor with the brackets in the rear holes, though. So I pulled the engine and trans back out, slid the six cylinder brackets forward, and drilled a hole for the bottom bolt. This has been working fine for me, I don't know if the engine is in a slightly different location than it should, but has not caused any problems.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 07-11-2019, 03:52 PM   #5
Red68
Red68's Avatar
Thanks Katrina/10,
That’s what I was planning to do and was going to check it out before I purchased new ones. Thanks!
Old 07-11-2019, 05:03 PM   #6
Katrina/10
Katrina/10's Avatar
I know what you want to do will work, but remember I have no idea whether it locates the engine in exactly the right place. I had to relocate the transmission crossmember for the 700R4 so that didn't matter. Maybe someone who actually knows the difference will respond.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
