Old 07-10-2019, 02:20 PM   #1
NorthernMatthew
NorthernMatthew's Avatar
1972 Blazer top/window seal issues
Hello everyone,
I'm hoping I can gain some insight from the experts on this fine forum. Last fall I had the hard top refurbished including NOS window to top weatherstrip seals and non NOS rubber to seal the top to the truck. The window weatherstrip was glued in and that glue gave way after a few months (pulled from the corner). They have since been re-glued and are holding but there is a slight gap from the seal to window at the corner on both driver and passenger doors. Also I'm getting some air coming in when driving from the driver's left top corner where the top meets the window header. Recently I learned that there are little T clips that are used to affix the seals to the top. I am guessing that these T clips position (center) the seal correctly and without them it's possible for the seal to migrate from it's correct position. Does anyone have knowledge regarding using these clips on a double wall top, how many are needed and do you think these missing clips are the root of these two issues?
NorthernMatthew is offline   Reply With Quote
Old 07-10-2019, 04:55 PM   #2
Jesse B.
Re: 1972 Blazer top/window seal issues
I'll share my personal experience/advice and I suspect most folks here will each have their own. I too have a double wall top and I bought new non-NOS door window to top seals because actual new NOS stuff is not available to me. I tried using the t-clips, I tried using weatherstrip glue, and I tried using super glue. None of it worked long-term and the seal quality sucked. I could barely get the driver's door to close and there were still gaps, and it was tough to roll the window down and roll the window up. I only tried one brand of seal, so maybe other brands fit better but I ended up ripping them off and repainting the window sill. I then went to the hardware store and bought a couple different shapes of regular stick-on door/window seals and tried those. All of them fit better than the repop seals. I settled with using a white D-shaped seal (because my top is white) and it seals fine, the doors close, the windows roll up and down, and the seal color matches the top, so you barely see it. It is not a perfect seal (if you directly spray a stream of water from a hose at it, it will leak), but it is close enough.
Jesse B. is offline   Reply With Quote
Old 07-10-2019, 05:18 PM   #3
jaros44sr
jaros44sr's Avatar
In my opinion, this is the weak point on blazer/jimmies, if there is one. the best glue is 3m weatherstrip glue used correctly! "T" clips are for single wall tops and 1/2 tops, I believe. Just don't drive in the rain, and you won't get wet, lol
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-23-2019, 01:07 PM   #4
notsolo
notsolo's Avatar
Hey Jesse, could you post a couple photos of your white weather strip mod....Same problem here, double wall top seal is fair, looks aweful....leaks a bit...
notsolo is offline   Reply With Quote
Old 07-23-2019, 01:26 PM   #5
NorthernMatthew
Hello everyone, any input is appreciated.
Old 07-23-2019, 06:51 PM   #6
notsolo
notsolo's Avatar
Hey, Matthew. Can't be sure my double wall top had the correct T clips....more like sharp on both end clips that rips the weather strip. Good bit of strain on the clips, weather strip adhesive will help but mine still got ripped because the rubber is thin.
Old 07-24-2019, 09:43 AM   #7
Jesse B.
Sure, here are some pics. One is with the window down, one is with the window up, one is a profile of the seal. It isn't a "D" like I wrote above, it is more of a triangle. I got it at the local Ace hardware. As I wrote above, it works well and looks nice, and I think think nicer than a factory black one against a white top. I do not notice any air or water leakage when I am driving the truck, although I did add about an extra inch or so at the very top corner where the top meets the door/window to get a good seal at that spot. It would not cost you much to just try it and see if it works for you as well.
Old 07-24-2019, 04:29 PM   #8
notsolo
notsolo's Avatar
Thanks for posting that, looks Great, a lot better white and better than what my gum..D up mess looks like.
Old 12-31-2025, 10:40 PM   #9
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I think this is the window weatherstrip Jesse B. used; I'm going to try it on my double wall hardtop:
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 01-01-2026, 12:48 AM   #10
NorthernMatthew
I still haven’t resolved the issue with my double wall seal issue. I think I lost track of this thread so am happy you commented. Let us know how it goes, looks like a good alternative.
Old 01-01-2026, 01:48 PM   #11
badpeanut
badpeanut's Avatar
FWIW, my double wall top is recently repainted and I found this thread looking for solutions.
I purchased the reproduction weatherstrip, but it looks like I would have to stretch it during install to make it reach. I also see the T-clip holes in my 1971 double wall top are in different locations than the T-clip holes in a second double wall top I have (I'm guessing this is why the holes are not pre-located in the weatherstrip). Gluing this reproduction weatherstrip on will leave adhesive and mess up my new paint, so before I commit to this I'm going to try the white window weatherstrip.
I ordered 1/4" white plastic plugs to potentially put in the T-clip holes to try along with the white window weatherstrip.
'70 GMC LWB trailer
Old 01-18-2026, 12:24 AM   #12
badpeanut
badpeanut's Avatar
The white 3/8" window weatherstrip doesn't seal on my hardtop due to the wear in my window regulators.
I bought some 3/4" from that jungle website that would be good, except the adhesive is poor.
'70 GMC LWB trailer
