11-30-2003, 10:54 PM | #1 |
Charging problem
I went to start my truck yesterday morning and it was dead. So I installed a new battery and the gauge is just on the "charge" side of center. I ran it a while yesterday and it never did come up to center like it was before. I went to start it today and it grunted once then started and the needle was about half way between center and the far edge of charge. So I ran it for a while and it still wouldn't come up to center, but just to the right of center. I came in and read a bunch of posts related to this problem and went to work. I did find the + cable was loose at the starter, but that didn't cure the problem. When I put the + clamp back on the + post I could hear something on the firewall "click". I traced it down to somewhere in the distributor area.... question: is this "click" normal?
And I'm thinking the problem is the voltage regulator.... is this probable? To solve this I'm thinking about getting an alternator/regulator combined. Which one do I get and where can I get the plugs to convert from what I have to a later model alternator?
Martin Gibson
USAF Retired 1964(-ish) C10 |
11-30-2003, 10:59 PM | #2 |
Formerly yellow72custom
First i would get the alternator tested.....pull it off and any parts store should test if for free.
Voltage regulator failure could be the problem....if so they cost like $12 and take 15 minutes or less to install....but upgrading to an internally regulated alternator would be a great idea....can't help you on the conversion process though. I still have a crappy external regulated alternator in my ride....
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
12-01-2003, 12:06 AM | #3 |
I'll take 'er in tomorrow evening after work and see what happens.... thanks!
Martin Gibson
