07-11-2019, 01:58 PM | #1 |
Active Member
Timing Tab
I haven't messed with timing marks for awhile and never with a big block. Isn't the balancer with the timing mark supposed to stick out beyond the timing tab so you can see it while making adjustments? This is what I'm looking at...
07-11-2019, 03:02 PM | #2 |
Re: Timing Tab
The balancer rubber has failed and the outer ring has slid back toward the engine block, even looks like it is rubbing on the oil pan flange. Replace that balancer and then your timing marks will line up as they should.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
07-11-2019, 03:19 PM | #3 |
Re: Timing Tab
^^^ This
72 C10 lwb fleetside -stock 350/350 combo |
07-11-2019, 03:38 PM | #4 |
Active Member
Re: Timing Tab
Aaah yes, I see what you are talking about.
Thank you! |
07-11-2019, 08:22 PM | #5 |
Re: Timing Tab
That balancer is junk
I BELIEVE IN JOHN 3:16 |
