![]() Join Date: Mar 2013
Spare Tire Carrier
Can anyone tell me if the under body spare tire carrier is the same for both the 1/2 ton truck and the Suburban? Or are they different? Thanks in advance
![]() Join Date: Feb 2011
Re: Spare Tire Carrier
Not sure, so here is my spare carrier from my 61' Suburban for comparison.
MusicMan70 1961 GMC Suburban |
Thanks, This is for a 64.
![]() ![]() Join Date: Apr 2012
Yes , pickup and Suburban are the same as pictured above.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Thank You
Was the 61 frame an X frame etc, and wider in the rear.?
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Yes, the 60-62 spare tire carrier is different because of the frame being wider in the rear.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
What years did they use this type of carrier?
I found this in my father-in-law's shed. He had a 73 GMC.
Moderator
![]() Join Date: Dec 2012
That looks like it will work. I can say for certain that a 63-66 carrier will work on a 67-72.
It looks like they were very similar for the 73+.
http://67-72chevytrucks.com/vboard/s...ighlight=Spare
![]() Join Date: Sep 2019
I was wondering what that piece was. I have one in my pile of parts that came with my truck and had no clue what it would be for. I won't be using it so no worries there!
![]() Join Date: Sep 2016
My 62 suburban had an"elevator" system.
A wire with a arm on the bumper to raise and lower it. |
