Old 07-11-2019, 07:56 PM   #1
Aaron Burkemper
Aaron Burkemper's Avatar
Need drive shaft help
First off, I am not interested in converting to a one piece drive shaft. This is an old farm truck, and it is just not worth the effort or expense.
Now then, I broke my rear drive shaft on my 71 C20 2 wheel drive with a corporate HO52 rear. This is the one that goes between the center carrier and the rear diff. I am having a HECK of a time finding a replacement, without going to a drive line shop and having the yokes put on a new tube.
Are there any donor vehicles other than the same truck that would work in a pinch? Preferably a vehicle that is easier to find.
I have had contacts that have C10 drive shafts.
I have had contacts that have the shaft for a truck with the Dana rear.
Both of these seem to be slightly different in length.
Can any of you help me out with some info?
1971 C20 "Shreck"
1980 C30 dump bed "Ratchett"
Aaron Burkemper is offline   Reply With Quote
Old 07-16-2019, 03:18 PM   #2
andrewpclayton
andrewpclayton's Avatar
Re: Need drive shaft help
I had the same problem and ended up having to have a shop fix it.. I couldn't get an answer on this question after some furious googling as it sounds like there is some variance even between c10s. Good luck
1977 SWB (c20 conversion) SBC350
Springfield Oregon
Instagram: @nevernotchevy
andrewpclayton is offline   Reply With Quote
Old 07-16-2019, 04:15 PM   #3
Aaron Burkemper
Well that stinks, but thank you for the reply.
1971 C20 "Shreck"
Old 07-16-2019, 07:33 PM   #4
bozly
it sucks, but its likely going to be easier to measure the length and have a driveline shop sort it out for you. I just had my '71 shortened last week due to how much I lowered it. They replaced U joints, carrier bearing, cut to length, balanced, and painted it for $300. I felt that price was more than reasonable because it was a problem I couldnt solve.
bozly is offline   Reply With Quote
Old 07-18-2019, 07:38 AM   #5
GWWhite
Had the same problem and took an old shaft same dia. shaft, cut the proper section, placed in an angle-iron/vice jig, welded it myself. Got lucky, I mean it is an old farm truck!
GWWhite is offline   Reply With Quote
