dog tracking suburban 4x4
Would anyone have the measurement of the wheel base of a 4x4 suburban front to back center of axle to center of axle. Mine will not track straight on the road and I can not see by eye where anything is off I'm hoping an axle is just slide on one side. You would not know it driving but it sure looks bad when you follow it. 1970 GMC all stock suspension
Thanks |
Suburbans RULE!
My '71 Burb is the same way. It feels like it drives staight as an arrow but if you follow it, you'd swear it was dog tracking. The wheelbase on the Burbs is 127".
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
Could be a broken center pin on your rear spring.
![]() Join Date: Jun 2003
just make sure you measure from axle to axle to get the same distance. i think they all look like that. you got to remember the track width on the front axle is wider than that of the rear. it makes it look as if the rear is dog tracking. my dana 44 is wider than my stock rear in my 72 burb.
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration ![]() 67' Chevy, What to do??? And Bad Ass American Bulldogs! |
![]() Join Date: Feb 2002
My '67 K/10 sub looked like it was dog tracking or "crabbing."
I thought it was due to trying a '69 model power steering set up briefly and that sheared the guide pin under the Dr side front spring pack. This was with a stock '67 corp front end. I have a '75 Dana 44 to swap onto it, once I get back to that project. |
On one of my lifted trucks, someone put one of the lift blocks on upside down. The tapered side was put towards the spring, but only on one side. This caused the axle to be out of square with the frame and it dog tracked. I flipped the block over and the problem was fixed. An easy thing to check, so give it a look. Also cross measure the rear springs make sure they are the same. Good luck
1957 Cameo |
its all about the +6 inches
Good way to double check and make sure it isn't the track width messin with your head, is to drive through a large puddle in an open parking lot. Keep driving straight, then get out and look at your tire marks on the pavement.
CCRider
If you can't seem to find the problem, have the front end alinment checked....even if it seems to go straight that could be the problem
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
![]() Join Date: Feb 2001
Long wheel base 4x4's tracked in one direction and the shorts tracked the other. Common. Another thing is people pulling a really stuck truck from justy one of the frame rails. Always pull from both sides. Those old rivets seem to let loose after time.
Keep in mind that the front track width is wider than the rear.
1957 Cameo |
Wiseass secured himself a BAN
Take it to a alignment shop and have them realign everything for you......This way you will know that is correct....
