Old 07-14-2019, 02:59 PM   #1
bigmoe
bigmoe's Avatar
Cast iron looking spray paint?
I have a new master cylinder (raw cast) and a brake booster (raw steel) that I would like to paint with that spray paint that looks like nice fresh cast iron. Just wondering what others are using. I see POR-15 makes a "detail paint" in various colors including Cast Gray. Not cheap though.
bigmoe is offline   Reply With Quote
Old 07-14-2019, 03:06 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Cast iron looking spray paint?
This is the best that I have seen.
In this link below
Link: https://www.eastwood.com/eastwood-br...y-aerosol.html
84 Chevy K-20
Old 07-14-2019, 03:22 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
I used the Eastwood paint on mine...color looks great...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-15-2019, 08:57 AM   #4
popstand
I use Dupli-Color Cast Coat Iron Engine Spray Paint, have used it for years on master cylinders and on my Saginaw power steering gear. Looks good, easy to clean, usually do 3 light coats so not to fill up casting surface. It’s actually a ceramic engine enamel I think. Great stuff, dries quick. Photo of my '53 with Camaro sub frame, booster, etc.
popstand is offline   Reply With Quote
Old 07-15-2019, 11:10 PM   #5
jocko
jocko's Avatar
Both of the above look nice. I've used eastwood's and was happy with the finish and, more importantly, its durability.
Old 07-17-2019, 11:08 PM   #6
hank scorpio
I know you mentioned it as expensive but the POR15 cast iron grey is amazing and will hold up even on exhaust manifolds. A little can of it goes a LONG way so the expense ins't so bad. (I've always used the brush on which dries perfect on cast surfaces).
64 C10
A bunch of Volvos
Luthier
Simpsons Nerd
hank scorpio is offline   Reply With Quote
Old 07-18-2019, 02:38 PM   #7
yote1234
yote1234's Avatar
i use "cast blast" come in a rattle can
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 07-18-2019, 05:47 PM   #8
damnyankee36
damnyankee36's Avatar
After glass beading or sandblasting, try an engine flat clear.
damnyankee36 is offline   Reply With Quote
Old 07-20-2019, 03:18 PM   #9
The Rocknrod
Moderator
The Rocknrod's Avatar
I took apart a master cylinder and had it jet hot coated in the past, works well.
Old 07-20-2019, 04:22 PM   #10
mongocanfly
Post Whore
I've used alot of castblast paint...not sure how it would hold up to brake fluid...whatever you use needs to be resistant to bf...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-22-2019, 03:10 PM   #11
Lugnutz65
Lugnutz65's Avatar
Calyx cream manifold dressing works well. Easy to apply with an old toothbrush and never cracks or peels. Reapply as needed without removing the part. Here’s my 230ci intake manifold with Calyx. The exhaust manifold has black wood stove cream dressing. My manifold still looks great 8 months later without any touch up (so far).
Here’s a video I made. https://youtu.be/K0AODe2mDw8
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 07-22-2019, 11:08 PM   #12
Backpayne
That Calyx stuff looks great! I'm tired of seeing my rusted master cylinder.
Backpayne is offline   Reply With Quote
Old 07-23-2019, 07:42 PM   #13
Mike_The_Grad
Mike_The_Grad's Avatar
I used the duplicolor cast coat spray paint on my dads entire 292. Looks great. I also used a clear coat that's rated for engine use on the master cylinder for my dads 64 c10. The clear coat kind of darkened the master cylinders natural appearance but is much more pleasing to look at than rust. I ended up using Nevrdull polish on the zinc chromate master cylinder cover. So theres gonna be dome upkeep involved with the polished items versus the painted stuff.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline   Reply With Quote
