Old 12-01-2003, 12:22 AM   #1
polevault1977
Pick'n up the pieces!
polevault1977's Avatar
One piece side windows revisited
This topic has been touch on a couple of times, but I'm throwing it out there again. I've got my doors completely stripped down and am defintely going with electric windows, but would like to have more info and one piece glass kits from Brothers, ECE, etc. Pros and Cons. Anybody been down this road? Danny
polevault1977 is offline   Reply With Quote
Old 12-01-2003, 01:21 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
If you p.m. pont he was the only one that helped me out and was very informitive..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-01-2003, 02:06 AM   #3
barn9
Half a bubble off!
barn9's Avatar
Here is the link to A-1, which everyone seems to like very well by the way. These are what I hope to put in one of these days.
http://www.a1electric.com/
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 12-01-2003, 04:26 PM   #4
71sub
71sub's Avatar
I installed A-1 power windows with the 1-piece windows from Brothers and it looks great, BUT ....
The glass "wiggles" a lot unless it's only rolled down 3 inches or rolled up 3 inches, not much support in the middle
Also, the power window motors are not very strong and may hang, especially with new rubber -- so you have to help it at times
Finally, since your doors are already gutted -- it's a pretty simple install using existing door hardware.
If you have any specific questions let me know
Ev
71 C/10 : 350 / 700r4 ; Ford 9" posi 3.50 with 31x10.5 rear tires, single drive shaft, C-notch, 2.5" drop spindles, keyless entry
71 Suburban 350/350 -- caddy tail lights, keyless entry, late model seats, billet Autometer instrument cluster
70 Ford Torino -- 351W (balanced & blueprinted ), C4, VDO gauges
71sub is offline   Reply With Quote
Old 12-01-2003, 09:51 PM   #5
my new 72
faster, faster, faster
my new 72's Avatar
Something is wrong with your install if the windows are hanging. It sounds like your door catches are putting pressure on the front channel and causing the binding, not the motors. The A-1 kit is the same one I used and everything is perfect. Everything works super smooth with no troubles ever. I'd check your install over again. And my windows don't rattle either, and they never have. When ever doing anything like this it pays to take a little longer than you think it should to do the job and make sure it is done right.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 12-04-2003, 12:38 AM   #6
polevault1977
Thanks for the info. Danny
