07-15-2019, 02:39 PM | #1 |
is it worth it?
I had a headliner installed in my truck with a heat shield backing. The upholsterer used sticky back velcro to keep it up. over the fairly hot weekend the sticky back became less sticky than it needs to be. We are going to try a stronger adhesive but I am skeptical of whether it will work. My question is. Is it worth it to drill holes in the roof/ceiling in order to keep it up. I am fine with how it looks without it but would really like to have the heat shield.
07-15-2019, 02:44 PM | #2 |
Re: is it worth it?
I used the heavy duty Velcro (2" wide, 30 ft roll that costs like $30 at Lowes) and it got hot/melted and now the headliner sags. I have no heat shield so that may be too much weight for the sticky part of the Velcro if it gets hot. I am going to go back and put the most stout adhesive I can find and a ton of it up there.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
07-15-2019, 03:37 PM | #3 |
Re: is it worth it?
I use a lot of Velcro at work and most of it doesn't hold up well to heat.
There is a 3M product that has VHB tape as a backing and it seems to work the better than the normal sticky back. On some applications we also use Velcoins that you can rivet or screw on. We don't sell it but I can get a part # or I can send you a small piece to try.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
07-15-2019, 04:12 PM | #4 |
Re: is it worth it?
What if you put the Velcro up with panel bond it won’t come off and you don’t have to drill holes I would put some in the center to help support the weight
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
07-15-2019, 04:25 PM | #5 |
Re: is it worth it?
do you have a part number for the one with the vhb backing?
07-15-2019, 04:28 PM | #6 |
Re: is it worth it?
07-15-2019, 04:30 PM | #7 |
Re: is it worth it?
I should do a heat test to see if it is any hotter inside the cab with the heat shield than without.
07-15-2019, 05:50 PM | #8 |
Re: is it worth it?
?? Just a thought I would think so you’re not putting fenders together I don’t think it would come off very easy make sure it’s what you want to do
07-15-2019, 06:45 PM | #9 |
Re: is it worth it?
I'm not sure how much tension is being put on the panel to keep it in place, but perhaps fastening some strong magnets to the back of your panel would do the trick. I use magnets frequently for non-invasive display installations. Rare earth type magnets are the stuff. You'd be surprised how much they can hold!
07-15-2019, 06:53 PM | #10 |
Re: is it worth it?
That's a good idea. I have played with them before and they are vary strong.
07-15-2019, 08:01 PM | #11 |
Re: is it worth it?
I made a headliner too http://67-72chevytrucks.com/vboard/s...d.php?t=741002 this one worked great with the velcro and is still holding strong. Then later I tried it again on my other truck and it sagged because and the plastic sheathing on my insullboard began to peel loose from the foam at the points of attachment. I ultimately removed that one. The magnet idea seems like a darn good one and may even inspire me to give it another shot. Thanks for that.
07-16-2019, 07:20 AM | #12 | |
Re: is it worth it?
07-16-2019, 10:22 AM | #13 |
Re: is it worth it?
It's 3M, SJ3518FR & SJ3519FR. The magnets are a good idea too. We can't use them on aircraft so I didn't think of that.
07-16-2019, 11:24 AM | #14 |
Re: is it worth it?
I have not used these exact magnets before, but the idea would be to pop rivet similar magnets to the back of a thin stiff panel which would serve as the foundation for your upholstery, then simply stick it in place.
https://www.amazon.com/DIYMAG-Neodym...s%2C182&sr=8-5 |
07-17-2019, 09:16 PM | #15 | |
Re: is it worth it?
07-17-2019, 10:16 PM | #16 |
Post Whore
Re: is it worth it?
Just be aware that a magnet stuck to the roof skin will attract all kinds of metal particles to the paint side of the roof...
07-17-2019, 10:29 PM | #17 |
Re: is it worth it?
why not big Dabs of silicone in a few choice spots.?
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
07-17-2019, 11:14 PM | #18 | |
Re: is it worth it?
I think we will try some stronger adhesive before I go with magnets. I would really like to use something that won’t pull off the paint if I want to get it off. |
07-18-2019, 01:29 AM | #19 |
Re: is it worth it?
I have some 3m vhb 'booger tape' that was used to hold placards in wheel wells of aircraft.. it's tough stuff, but I can't give you the number until I get home from vacation.. seems I posted about it here before in an emblem thread, might still be there..
I started out with nothing - and I still have most of it |
07-18-2019, 02:31 PM | #20 |
Re: is it worth it?
I used something else it worked great
07-18-2019, 02:31 PM | #21 |
Re: is it worth it?
07-18-2019, 02:33 PM | #22 |
Re: is it worth it?
07-18-2019, 02:37 PM | #23 |
Re: is it worth it?
It really did !!
07-18-2019, 02:43 PM | #24 |
Re: is it worth it?
I'm sure it did but what is it.
07-18-2019, 02:47 PM | #25 |
Re: is it worth it?
The same stuff one of the previous posters used, when he installed his headliner.
