Old 07-16-2019, 12:51 PM   #1
weim55
Questions on 16 inch Ford wheels that fit C20s
I’ve heard reference here on the boards to a 16 inch Ford wheel that will fit our three-quarter tons. I’m looking for a 16 x 7 or 16 x 8. Does anyone know the original application of these wheels so I know what to look for in a junkyard? Possibly an Accuride number if I purchase new? Are these wheels a straight bolt on ( lug studs and wheel center same? ) and will take the original hubcaps from my 69 C20?
Thanks,
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 07-16-2019, 04:29 PM   #2
54blackhornet
54blackhornet's Avatar
Re: Questions on 16 inch Ford wheels that fit C20s
When I got my 71 C20 it had split rims on it. I was given a set of 16 in Ford wheels off a 90’s truck, not sure exactly what model but they fit perfectly caps too.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 07-16-2019, 06:32 PM   #3
weim55
Do you know what size those wheels are, 16 x 7?
Thanks,
Old 07-16-2019, 07:26 PM   #4
72Cheyenne454
72Cheyenne454's Avatar
The Ford Accuride wheels are 16x7
Dorman reproduces them if you can't find a used set
https://www.summitracing.com/parts/r...-198/overview/
72Cheyenne454 is offline   Reply With Quote
Old 07-16-2019, 07:49 PM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
My wheels are off a 97 E250 and are 16x7.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-16-2019, 07:52 PM   #6
72c20customcamper
72c20customcamper's Avatar
Exclamation Re: Questions on 16 inch Ford wheels that fit C20s
1996 Ford f250 rims. Got them from Roadreadywheels.com
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-16-2019, 08:28 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Most every 90’s E350 in the junkyard will have them. LKQ has Monday madness wheel sales sometimes and they are $10 each then. They are 16x7, fit perfectly, and accept dog dish caps. I run them on my 72 k2500
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 07-16-2019, 08:49 PM   #8
Grumpy old man
Grumpy old man's Avatar
Alcoa made a 16" aluminum rim for Ford . Mounted here on this c 20 ,They were stamped with the Ford logo
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 07-16-2019, 09:00 PM   #9
65standard
65standard's Avatar
Ford 8-lug wheels have a bigger center bore making them not hub centric when on the Chevy truck. The junkyard by me has plenty of 8-lug Chevy rims that fit best.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 07-16-2019, 09:28 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
I bought one 16" wheel at a local wrecking yard that came off a 2000 Suburban. It fits the bolt circle and has the same size hole for the hub. I don't know if a hub cap fits, but the wheel does bolt up. I also did not measure the width, couldn't tell you why. They nicked me $$ for it. I needed it to be sure I had a spare when we went camping a year or so ago, and driving 30 miles for a cheaper wheel seemed to be stupid, at the time. The new tires I bought a couple of years ago will age out before they have too many miles on them. I'm thinking that maybe I could work out some sort of trade with somebody, where they can use up the rest of the rubber before mine go bad. The thing about rubber now is that tires are only claimed to last 5 years, and by that time, the warranty has expired, even if they have plenty of tread.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 07-17-2019, 12:02 AM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My 16x7 F250 steelies came from a junkyard a few years ago. I had them powdercoated and mounted with 255/85 Coopers. Never gave a thought to them not being hub-centric. I have run at least two other sets of wheels with larger hub openings and never had a problem. Once you snug up those eight lugs, nothing is going to move around.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-17-2019, 07:36 AM   #12
Only the factory wheels were hubcentric. All your aftermarket wheels for 8-lug: aluminum slots, Kelsey Hayes 9.75s, turbine style, Jackmans/wagon wheels, Outlaw IIs, saw blades, AR23s, d-hole, Barts, all of them, were lugcentric. All Dodge and Ford 8-lug wheels fit GMs right up until they bumped their heads and went halfass European on us by going to a metric pattern that is so dangerously close to the SAE pattern, that has existed since the wheel was invented, it only serves to offer a seriously dangerous situation. You can't "see" the difference between 6 1/2" pattern and 170mm. If the wheels are from before '96 or so, no problem. But in the '90s better check. The Vans stayed SAE but the hubcap nubs were dropped on the latest years. As far as SAE Pattern Ford E & F 250/350 16 x 7 steel wheels go, you need to look for the Accuride stamp. No stamp = halfass metric
Old 07-17-2019, 08:59 AM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
Damn. I better check my spare wheel again. Seemed like it fit OK, when I tried it. It's an obvious ~3/16" difference, but I only put it on the rotor, I didn't put the nuts on.
~Steven
Simi Valley, CA
Old 07-17-2019, 09:01 AM   #14
CG
BlahBlahBlah
Wish you were closer. Im getting rid of all my 3/4 ton stuff and I have a set of these wheels I would let go for 40 bucks. But shipping them is out of the question.
Old 07-17-2019, 12:00 PM   #15
weim55
Wow, just great information everybody! This will help my search a great deal!
Old 07-17-2019, 12:04 PM   #16
weim55
Is LKQ a wrecking yard chain? Not sure I’ve heard of those here in Colorado?
Old 07-17-2019, 12:51 PM   #17
leddzepp
Moderator
leddzepp's Avatar
They own almost every pick a part on planet earth these days
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 07-17-2019, 01:38 PM   #18
weim55
Oh, OK. I’ll look into that and see if they own the Pick a parts here. Thanks for the heads up!
