1980 Fan Shroud W/AC
Anybody know where to get a fan shroud for a 1980 Chevy Pickup V8 with AC? Can't find one listed anywhere.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
Re: 1980 Fan Shroud W/AC
Did you check them out here
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
If not then your going to have to try wrecking yard that has lots truck of the 73-80.
I think you need the top section mostly. I be leave the bottom is the same in one of the option or will work with the top. I have to see them as I do not remember any more It's been along time I checked that out. If it the None a/c or the a/c option can work.
Good thing you don't need one for a 6.2L diesel they are almost impossible to find! I don't know much on Gas Specific parts though! Best luck Maybe some Aftermarket websites, like LMC/USA1/Classic Industries etc... or Yes the local Wreaking yard.
Called LMC, they don't have one and they don't know of anybody that does. The A/C radiator is taller and the non A/C is shorter.
