Old 12-01-2003, 01:00 AM   #1
71swb4x4
71swb4x4's Avatar
Lockout hub is loose
My lockout hub is loose. I noticed it today after getting back from a short trip. Is there a way to just tighten it? I have a feeling that it may need more than just tightening. Is the loose lockout a sign of something much worse? I have had no time to look at it, been too busy sitting at the computer Any thoughts would be great.
71swb4x4 is offline   Reply With Quote
Old 12-01-2003, 07:11 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
It probably is just loose. The older hubs are notoroius for loosing. Tighten it up evenly checking the selector as you go. Should have lock-tight blue I believe on the bolts.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
