07-17-2019, 06:44 PM | #1 |
Panel below the tailgate - how to install right?
Years ago I dismantled the 66 and during the bed removal I was unbolting panels and found that that panel that sits below the tailgate is welded on in 2 spots on each side..or at least mine was.
I have been sandblasting and repainting and will hopefully someday be reassembling. Before that day though I wondered if I need to weld it back together in those spots before I paint? The panel is on its own now sandblasted and has epoxy primer, needing 2k next. Whats the right way to go about this? Here is a pic from 2015 when I tore it down |
07-17-2019, 06:47 PM | #2 |
Re: Panel below the tailgate - how to install right?
the upper and lower portions were welded on from what I remember
the upper was welded where I am pointing, and the lower area has a spot on the edge as well that was welded |
07-17-2019, 06:50 PM | #3 |
Lower spot I'm talking about
07-17-2019, 06:57 PM | #4 |
Moderator
You can just bolt it in. The weld is to make it easier to assemble at the factory.
07-17-2019, 08:47 PM | #5 |
1965 Chevy C10, 2005 4.8L/4l60
What Jay said!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
07-17-2019, 09:02 PM | #6 |
Whew, thanks guys!!!!
07-18-2019, 05:49 PM | #7 |
Yeah, the four bolts in each corner have way more strength at keeping things square than a single weld. Definately not needed.
FWIW, I understand GMC's were apparently not welded. |
