![]() Join Date: Jul 2016
Tilt column, column shift auto, (pre sale) the real deal.... another one
This is another clean column, somebody did an amateur restoration on it in satin black which looks like crap so Im bead blasting it and painting it the proper gloss black. As you can see its a clean column overall with no rust pitting on lower column and only light surface rust on the center shaft which i will wire wheel off.
You should note this has the proper short center shaft and lower mounted neutral safety switch along with truck grommets and retainers. I explained here http://67-72chevytrucks.com/vboard/s...d.php?t=790316 what makes one of these tilt columns a real truck tilt. This will have the following new parts upper and lower grommets turn signal and tilt levers lower bearing retainer Shift pointer Fully serviced, lubed and set to factory specs. Ready to bolt in with no modifications required. $525 shipped. If paid for in advance i can have it ready in 2 days otherwise i might take a few more days to complete it. |
Re: Tilt column, column shift auto, (pre sale) the real deal.... another one
Randy, left you a VM.
Ill take it refinished
