Old 07-18-2019, 12:12 PM   #1
duke10
Active Member
duke10's Avatar
Squeaky truck
I have a 1970 3/4 ton GMC Custom Camper that has been squeaking like crazy when I turn the wheel left or right. Noise is intermittent and there is no rhyme or reason. It doesn't seem to have anything to do with weather, temperature or whether it is warmed up or not. Truck drives and runs extremely well, it just sounds funny.
I have greased everything I can find under the truck and it didn't seem to solve the problem.
Any ideas?
Thanks in advance
duke10 is offline   Reply With Quote
Old 07-18-2019, 12:26 PM   #2
Mts67C10K20
Mts67C10K20's Avatar
Re: Squeaky truck
Does it have polyurethane bushings
They like to squeak
Good hunting
Mts67C10K20 is offline   Reply With Quote
Old 07-18-2019, 12:31 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Squeaky truck
Front wheel bearings?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-18-2019, 12:45 PM   #4
Wrenchbender Ret
Re: Squeaky truck
If it still has the original pitman arm &/or idler arm they can cause that. The originals do not have grease fittings. The replacements generally do have grease fittings.
George
Wrenchbender Ret is offline   Reply With Quote
Old 07-18-2019, 07:35 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Squeaky truck
If it is like George says with no lube fittings on the parts, try a little penetrating lubricant sprayed on them one at a time until the bad boy shows up. If they're the culprits, they'll quiet down. Might take a day or two for the lube to work, though.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 07-18-2019, 07:53 PM   #6
mr.precision
mr.precision's Avatar
Re: Squeaky truck
When I got my '67, the idler arm was bent and rubbing against the cross member (if I recall correctly). Would squeak like heck when turning. I removed it and straightened it. No more noise. Just a thought.
mr.precision is offline   Reply With Quote
Old 07-18-2019, 10:31 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Squeaky truck
Right. With trucks this age, you just never know what could be going on. Though that sounds like a "Dukes of Hazard" kind of problem.
~Steven
Simi Valley, CA
Old 07-18-2019, 11:44 PM   #8
406flyfish
Re: Squeaky truck
Check your upper and lower ball joints they can also make the noise. You can also isolate the noise with a stethoscope for a auto parts store
406flyfish is offline   Reply With Quote
Old 07-19-2019, 01:43 PM   #9
weq92f
weq92f's Avatar
Recently I traced a squeak down to my upper control arm bushings. A little grease there fixed it right up.
HTH
-klb
weq92f is offline   Reply With Quote
