Old 07-19-2019, 04:25 PM   #1
nlped
nlped's Avatar
Hunting an original style air cleaner “elbow”
Like the title says, I’m hunting the rubber boot/elbow that goes from my original equipment air cleaner assembly to the hole in the core support. It’s for my ‘87 TBI truck.
I’ve added a picture for reference.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-19-2019, 05:42 PM   #2
Stormin08
Stormin08's Avatar
Re: Hunting an original style air cleaner “elbow”
man, good luck...i have spent several hours today looking my self.
i am retro fitting an inlet to make a dual intake, and would like the factory tubing...
i even went as far as to search for the older summit/jegs tbi power package, NO LUCK.
if i find something, i will post it here
Stormin08 is offline   Reply With Quote
Old 07-19-2019, 05:45 PM   #3
Stormin08
Stormin08's Avatar
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=154
just remembered this....
Old 07-19-2019, 05:54 PM   #4
nlped
nlped's Avatar
Originally Posted by Stormin08 View Post
I saw this, but it says 81-86. I figured the 87 was different due to the TBI?
Carter
Old 07-19-2019, 05:58 PM   #5
Stormin08
Stormin08's Avatar
i doubt the tube differs that much, i am going to purchase 2 and fit them to my 89 once i finish the mod.
Old 07-19-2019, 06:12 PM   #6
mongocanfly
Post Whore
mongocanfly's Avatar
If I hadda known..I threw 2 of them away....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-19-2019, 07:00 PM   #7
Encinoman45
This style was only made in 87 and 88, and are not currently reproduced.
Go to car-part.com
Enter search for 87 and 88 suburban.
There are really no results for just an air tube so select Air Cleaner. I guess they don't think its worth listing.
You will get a bunch of results. Some even have pictures. Look through the pictures and pick out the results that show the air tube in the engine bay, and start calling. A lot are cracked, so you need to make sure they inspect the tube. You might have to get them to do a package deal of the air cleaner and tube together. In my case, I ordered the air cleaner and they threw in the tube for free.
Encinoman45 is offline   Reply With Quote
Old 07-20-2019, 10:34 AM   #8
nlped
nlped's Avatar
Gahhhhh!!! Greg! You’re killin’ me man!
Carter
Old 07-20-2019, 10:35 AM   #9
nlped
nlped's Avatar
Go to car-part.com
I’ll check that out. Thanks!
Carter
Old 07-20-2019, 01:05 PM   #10
SCOTI
SCOTI's Avatar
Good luck guys. Please post if you find something. I ended up w/an open element set-up as I couldn't find what I needed for my 89 CC Dually set-up.
I've been looking at alternative air cleaner housings (OE & not the Spectre aftermarket looking stuff) that I can adapt 4" hosing to. I was successful after being tasked w/a similar set-up for a car so I began the hunt again for my dually.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-20-2019, 02:40 PM   #11
mongocanfly
Post Whore
Sorry Carter....I got tired of tripping over em....haha
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-21-2019, 09:56 AM   #12
KrazyRay
KrazyRay's Avatar
I have a good one pulled from an 88 Suburban. $45 shipped. I will check to see if I have another one on my 88 dump truck.
KrazyRay is offline   Reply With Quote
Old 07-21-2019, 10:55 AM   #13
nlped
nlped's Avatar
I pm’ed you...
Carter
Old 07-22-2019, 08:11 AM   #14
Pontiac1976
Pontiac1976's Avatar
The LMC 81-86 is straight for the carb set, the 87 TBI hooked because the air cleaner base nose is shorter @ different angle. (87 TBI air cleaner base, needs the 87 TBI air inlet tub to work.)
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-22-2019, 08:32 AM   #15
Pontiac1976
LMC does sell two one is longer I think you might make it work by modifications to it.
Maybe fill towels one end shape the angle heat the tube enough with a heat gun to relax plastic let cool in that shape you need should hold to it better) try not to melt it.
your best bet for one would be scrap yard that has 87 gas TBI
Old 07-22-2019, 10:07 AM   #16
nlped
nlped's Avatar
I’ve located one from KrazyRay. It’s enroute now.
Carter
Old 07-22-2019, 11:50 AM   #17
TKCR
TKCR's Avatar
KrazyRay has come to the rescue again. Ray has helped me out numerous times in the past.
Old 07-22-2019, 04:02 PM   #18
KrazyRay
KrazyRay's Avatar
TKCR... You have helped a bunch of members here also. This is a great site!
Old 07-22-2019, 10:54 PM   #19
82Diesel
Those are pretty rough to find, Much like the 81 Under Vaccum Style Inner Fender-mounted Cruise control units... If it was a 6.2L diesel they are nearly impossible to find... Luckily I found one for my 6.2 in my "parts" stash... haha.
I would think B/c It's on a Gasser Some Aftermarket company would sell them.
Should be all the Same for Carbed or TBI.
82Diesel is offline   Reply With Quote
