Old 07-21-2019, 02:29 AM   #1
SavageC20
SavageC20's Avatar
Will These Valve Covers Clear Roller Rockers?
I have a set of vintage Mickey Thompson aluminum valve covers that came on my c20 when I bought it. When I refreshed the 454 I didn't have time to restore the covers and put them back on. Now I have time and before I restore the covers I was wondering if anyone would be able to tell me if these are tall enough to clear roller rockers. Yeah I know I could take one of my valve covers off and test fit them but the covers that are currently on the engine are deformed and slightly leak so I don't want to risk deforming them more before I have the
M/T covers restored. Also, do I need the drippers with roller rockers?
Here are some pics:
SavageC20 is offline   Reply With Quote
Old 07-21-2019, 09:14 AM   #2
Mike C
Mike C's Avatar
Re: Will These Valve Covers Clear Roller Rockers?
I can’t say definitively they will, but IME, Mickey Thompson did not make a short or stock heigh valve cover so I think it is a reasonable gamble you would have no issues.
Do those covers have drippers in them? If so, that COULD be an issue.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Mike C is online now   Reply With Quote
Old 07-21-2019, 11:32 AM   #3
SavageC20
SavageC20's Avatar
Yeah they have drippers in them. In the picture with the part number you can see one of them directly above the part number. I am not opposed to cutting them off if they are in the way.
Old 07-21-2019, 03:01 PM   #4
Barnfind46
Barnfind46's Avatar
I would think that they would clear but if not, there used to be some spacers that the racers used to raise the cover up to clear. The up side is you get to keep the covers. The down side is you use twice the gaskets and another place that could potentially leak.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 07-21-2019, 03:36 PM   #5
weq92f
weq92f's Avatar
If you find they are real close, get a set of Fel-Pro gaskets like their "one piece" oil pan unit. They are thick and have metal sleeves at each stud point so there is very little smashing of the gasket. Should give you an extra bit of clearance.
Spendy but you can reuse them over and over!
https://www.summitracing.com/tx/part...make/chevrolet
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 07-21-2019, 04:12 PM   #6
hjewell2
hjewell2's Avatar
On my 454 with M/T covers and Harland sharp rollers the number 1 and number 2 rocker hit the edge of the covers I had to grind just a touch of corner on those two rockers. I ran it for years and was not easy on the motor the whole time I had it.And yes I had to clip the drippers.
hjewell2 is offline   Reply With Quote
Old 07-22-2019, 11:05 AM   #7
un4gvn!
un4gvn!'s Avatar
I bolted MT covers with Howard Cams roller rockers. They bolted down. I thought they cleared. Started up the motor and heard all hell braking loose for a couple of seconds. Before I tuned off the engine, it got quiet. I took off one side of the valve cover and every dripper was broken off. Luckily I found all the drippers before they wound up down in the engine. Took off the other valve cover and they were also broken off. I ground down smooth what was left of the drippers and reinstalled the covers never to have any more problems.
un4gvn! is offline   Reply With Quote
Old 07-22-2019, 08:14 PM   #8
SavageC20
SavageC20's Avatar
Thanks for all the info. I'll go ahead and restore these covers and cut the drippers off. I have seen those fel-pro gaskets before but I have never shelled out the coin for them. I might have to give them a shot. Thanks again everyone.
Old 07-24-2019, 04:01 PM   #9
un4gvn!
un4gvn!'s Avatar
I had the same problem with my rockers. When I was installing them, I came across two rockers that were rounded on one side. At first, I thought they were defected rockers. Then common sense kicked in. There was nothing about these two rockers in the instructions.
