Old 07-21-2019, 11:23 AM   #1
wpavlis
Fuel pressure regulator install picture request
I am thinking about installing a fuel pressure regulator. I have a 68 with a 350 and an edelbrock 1405 installed. I searched and had trouble finding any good pictures. Currently my fuel line is hard piped from the mechanical fuel pump to the carb. I am not super good with routing hard lines and i figured someone on here has found a good clean way to mount one. I was planning on using Holley 12-803. Thanks!
wpavlis is offline   Reply With Quote
Old 07-21-2019, 02:35 PM   #2
Jcfcamaro
Jcfcamaro's Avatar
Re: Fuel pressure regulator install picture request
I mounted mine to the head then used Earl's fittings.
Jcfcamaro is offline   Reply With Quote
Old 07-21-2019, 03:59 PM   #3
72LB
72LB's Avatar
Mines in the same spot as Jcfcamaro is.
[IMG][/IMG]
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 07-23-2019, 11:22 AM   #4
wpavlis
Those pictures were great. Thank you both!
