Old 07-21-2019, 08:39 PM   #1
anew4961
1971 chevy truck 7041206
1971 CHEVY OR GMC CARBURETOR IT HAS BEEN REPLATED NEW THROTTLE SHAFT BUSHINGS NEW SECONDARY CAM, IN SOME CASES I ALSO INSTALL SECONDARY BUSHINGS WHEN NEEDED WELL PLUGS WERE SEALED WITH EPOXY WELL PLUG SEAL INSTALLED NEW FUEL FILTER & SPRING A MASTER KIT WAS INSTALLED WHICH INCLUDES NEW FLOAT AND OTHER PARTS NEW PUMP RETURN SPRING NEW CHOKE PULL OFF IT WAS DONE RIGHT THIS IS FOR A AUTOMATIC TRANSMISSION DATE CODE IS 0661 FE $ 275.00 SHIPPED I HAVE THESE REPLATED AND BUILD THEM MYSELF ANY QUESTIONS PLEASE FEEL FREE TO ASK
PAY PAL ACCEPTED NO FEES TO BUYER
anew4961 is offline   Reply With Quote
Old 07-23-2019, 07:15 PM   #2
anew4961
Re: 1971 chevy truck 7041206
on hold for Harold Holbrook for sale
Old 07-24-2019, 04:29 AM   #3
Harold Holbrook
will take pending agreement
Harold Holbrook is offline   Reply With Quote
Old 07-24-2019, 02:39 PM   #4
dfosh
Do you run these and set them up or is that up to the buyer? Thanks
dfosh is offline   Reply With Quote
Old 07-24-2019, 03:12 PM   #5
anew4961
all you have to do is set fast idle for choke which faceing engine is on the left side and set base idle which is 650 for manual trans 700 - 750 on auto in drive and set air mixture screws i have thoes pertty close no two engines run the same hope that helps
Old 07-25-2019, 03:43 PM   #6
anew4961
sold to harold holbrook thanks again
Old 07-29-2019, 05:47 PM   #7
Harold Holbrook
Received my carburetor today it is beautiful. Thanks again Jesus you are a real professional.
Jr.
