Old 07-22-2019, 02:59 AM   #1
MiraclePieCo
MiraclePieCo's Avatar
Gas Tank Removal Safety Tips Please
I have a first-gen Camaro gas tank in the rear of my panel and for some unknown reason I run out of gas at 1/4 full on the gauge. So I need to drop the tank to access the sender to see what's the problem. Any safety suggestions for removing a tank full of fumes?
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 07-22-2019, 03:36 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Gas Tank Removal Safety Tips Please
Ive use a high temp 3m 433 silver tape over the fill tube when I pull mine out...mostly just to keep gas from spilling in the shop floor..works for fumes as well
and don't do it in a closed shop...have a fire extinguisher handy as well
you may just need to adjust your float..does it read over full also?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-22-2019, 10:31 PM   #3
_Ogre
_Ogre's Avatar
just use a floor jack
shop air compressor timer
Old 07-23-2019, 01:49 AM   #4
MiraclePieCo
I think it does read over full. I'm guessing that the float is hitting the tank floor at 1/4-full on the gauge so I need to raise the float?
Will do.
Old 07-23-2019, 03:25 PM   #5
jweb
jweb's Avatar
It my be the ohms of the gauge vs the ohms of the sending unit.
I think the truck stock gauge is 0-30 and the Camaro sending unit is 0-90. If that's not the problem than an adjustment to the float should fix it.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 07-23-2019, 06:39 PM   #6
72Mountaineer
72Mountaineer's Avatar
Do it logically. Find out how many gallon tank you have. Drain the tank (as much as possible), measure the ohms, add 5 gallons, measure the ohms, 5 more gallons, measure again. See where your gauge reads at each filling, then you can tell how far off the gauge is to the actual amount in your tank. Removing the tank should be the last resort.
72Mountaineer is offline   Reply With Quote
Old 07-24-2019, 03:20 AM   #7
mr48chev
mr48chev's Avatar
Carry a gallon of gas with you drive it until you know it is out of gas, put enough in to get back home and then pull the EMPTY tank. I don't know how many tanks I pulled that some idiot had stopped at a station on the way to the shop and filled the tank when I worked in a Pontiac dealership in Texas and for some reason gas tanks were on my job list.
Don't smoke while pulling it and don't use an old school drop light with an incandescent bulb. A floor jack or transmission jack or even a motorcycle jack works pretty good to save dropping it on yourself.
Check the range of the sending unit with the sender out of the tank and grounded to the truck with the wire to the gage hooked up.
My ongoing truck projects:
