Old 07-22-2019, 12:48 PM   #1
forestb
forestb's Avatar
My baby started bleeding this weekend
My baby started bleeding this weekend. I was on the freeway and my crankshaft pulley completely sheared off and cut open my lower radiator hose. I have no idea what caused it all the bolts are tightened down to the piece of the pulley that is still attached to be balancer.
forestb is offline   Reply With Quote
Old 07-22-2019, 05:29 PM   #2
MikeN
MikeN's Avatar
Re: My baby started bleeding this weekend
I had that happen once on a 350, the hub of the harmonic balancer was cracked and the balancer flew off the end of the crankshaft while I was driving down the road. I would guess your pulley had a crack, either from old age or use, or possible improper installation.
MikeN is offline   Reply With Quote
Old 07-22-2019, 10:13 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Bummer!
50+ year old pulley. No telling what happened to it over the years.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 07-22-2019, 11:02 PM   #4
Captainfab
60-66 Nut
So if I am understanding correctly, the crank pulley came apart? Had you noticed any vibration prior to this happening?
Old 07-23-2019, 07:58 AM   #5
kens65fb
Maybe the pulley broke
kens65fb is offline   Reply With Quote
Old 07-23-2019, 01:10 PM   #6
forestb
forestb's Avatar
correct. I had not noticed any vibration. But it was making a little squeaking sound mostly when first starting it up. I don't know how old the pulley is it's a 350 that I don't know the age of.
Old 07-23-2019, 11:23 PM   #7
Captainfab
60-66 Nut
I haven't seen a pulley come apart like that before. It must have been damaged or cracked and you just did not see it. All I can say is just replace the pulley with a new one and keep an eye on it for a bit.
Old 07-24-2019, 11:29 AM   #8
forestb
forestb's Avatar
I took it to the mechanic yesterday because I wanted him to diagnose the cause and not just fix the problem. He said that the rod for the water pump pulley also go bent in the process. The water pump is less than a year old. he also said it put a dent in my radiator but it is not leaking. the crankshaft pulley might have been cracked.
Old 07-26-2019, 07:33 PM   #9
rvrfoot
Do you have pictures?
rvrfoot is offline   Reply With Quote
Old 07-26-2019, 11:35 PM   #10
forestb
forestb's Avatar
No I don’t. I got it back today and all seams well. New water pump and 2 new Mr gasket pulleys. They also made me some new trans cooler lines The old ones were leaking and
About a half inch away from my headers.
