Electric fan kit ?
Which brand or set-up is everyone using .
Old member
I made my own. Not that hard to do and way cheaper.
2 roll's of Wire RED & BLack for hot & grounds 1- Thermastat controller for low speed fan 1-Relay 1-Toggle switch 1-36 volt 250 amp Micro switch About 10" of thin metal to make a paddle with. Here a link to my setup's I redid the wiring though. I bought a 5 connector relay and have the low speed wired to terminal 87A which comes on whenever the car is on but the fan has a thermastat so unless it's hot the fan want come on until it reaches the set point. Then I wired the high speed to 87 on the same relay this turns on when the AC comes on and it cut's off the low speed to the fan. Once the car starts moving the pedal will cut the micro switch off which in turns cut the fan off.I didn't want to take the system a part to install a brainery switch and this has worked great for over 2 years now in the 64 Impala and 4 years in my 71 C 10. http://67-72chevytrucks.com/vboard/s...d.php?t=738555
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 07-24-2019 at 08:03 AM. |
Re: Electric fan kit ?
I bought 2 12" electric fans with relay and the temp probe that you stick into the rad on ebay, so far been working great with no issues.
Active Member
![]() Join Date: Jun 2018
I'm using a jeep cherokee fan mounted in the stock BB radiator shroud. There are a few threads about it on the site. It's powered off a flex-a-lite controller (p/n 31163). It's not the cheapest, but it has the following features:
manual on, and manual off adjustable fan start setpoint soft start and variable speed control based on temperature fan start on a/c compressor signal in-water temperature probe (not radiator fin probe) I like this setup more than running a relay connected to a temperature switch, but that's me.
1971 Pontiac Firebird 1971 GMC C2500 |
I will be doing the jeep fan conversion later on as well. There's a very informative post on here too
1971 C20 Longhorn 350/350 "Conquistador" |
I am using a ford windstar dual fan setup in my 72K10. It has a 6.0 LS swap but I used the stock radiator. Fits good. I trigger the fans from my ECM but stand alone controls are available. i think it was $45 at the upull..
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
What's the allure of electric fans, if I may ask?
Frees up space in the engine bay, frees up some strain to engine, more efficient than a fan clutch.
Active Member
Electric fans won't cut your arm off if you accidentally hit them, and they're quieter.
With my LS swap in my K10 the transfer case is in the stock position. The engine is very close to the firewall. With the electric fans I will be able to add a 700r4 or 4l60 (2" longer than a turbo 350) with the transfer case in stock position just by sliding the engine forward...and it's much quieter too.
Blue 67
![]() Join Date: Apr 2004
Ford/Lincoln mid 90s V8 engine fans move over 2500 CFM and they can be bought new for $60 or so. They have small shroud as well which can be modified to fit. With relays and other small parts you can have an electric fan set up for around $100.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
So I found a Jeep fan (and it's a 2014 replacement for the 2002 recall
![]() AND I found a Volvo C70 relay setup, sooooo... Hypothetically, could I wire the Jeep fan to the Volvo relay??? |
#13 |
Yes you can use the volvo set up. I'm using late 90's f body fans with a temp switch to ground the relay for now but I want one that comes on a little sooner.
#14 |
For mine (drag car): quicker warm up time, and you can allow the fan to keep running with the engine off to cool it between rounds.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
