Old 07-24-2019, 06:00 PM   #1
puttputt1977
S10 Transmission Question
So I have a 1965 longbed with a 327 in it. It already has a 3 on the floor but the shifter is to close the seat. I'm wanting to put a s10 transmission in it. What all do I need to put one in my truck besides the transmission its self. Thanks for any info.
puttputt1977 is offline   Reply With Quote
Old 07-24-2019, 11:36 PM   #2
slepysal
slepysal's Avatar
Re: S10 Transmission Question
Lots and lots of info using the search .
here is one from the faq section
http://67-72chevytrucks.com/vboard/s....php?p=4871869
and one from LUGNUTZ
https://lugnutz65chevystepside.weebl...rear-axle.html
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 07-26-2019, 07:18 PM   #3
rvrfoot
Why a s10 trans????????
rvrfoot is offline   Reply With Quote
Old 07-27-2019, 05:31 PM   #4
puttputt1977
That's what I was told would bolt up to my 327 and they are fairly cheap to find.
Old 07-27-2019, 09:34 PM   #5
slepysal
slepysal's Avatar
your welcome for the links
Old 07-28-2019, 12:35 AM   #6
jocko
jocko's Avatar
The real reason it's a good idea is because it's a 5-speed trans with overdrive - and the S10 variant of the T5 has the stick in the right place to clear a bench seat. Low highway rpm is the benefit. It's light duty, but is fine behind a small V8 as long as not abused. There a few "world class" S10 transmission out there, but not many - WC is slightly beefier. The best combo is a Camaro main case with an S10 tailshaft - avoids the spacing required with an S10 input shaft yet has stick correctly located.
Just about any trans GM ever made will fit behind your 327.
Those ARE some good links by the way...
Old 07-28-2019, 12:48 PM   #7
slepysal
slepysal's Avatar
Those ARE some good links by the way... [/QUOTE]
Old 07-28-2019, 02:38 PM   #8
Vincenthdfan
The previous owner that I bought my 62 SWB from installed a World Class Camaro T-5 with an S-10 tail housing.
It is an outstanding combo and I really like it. It fits like it was made for the truck, shifts like butter...cant beat it.
I just installed a brand new crate 350 motor but have no intentions of driving it hard, so trans should last a good long time (knock on wood).
If I ever win the lottery or get the desire to do burnouts I may upgrade to a different trans at a later date, but for now I'm plenty thankful for the trouble the previous owner went to on my truck.
Vincenthdfan is offline   Reply With Quote
Old 07-31-2019, 02:16 PM   #9
puttputt1977
Sorry about that. I appreciate your help. A lot of great info there. Thanks again.
Old 07-31-2019, 09:46 PM   #10
slepysal
slepysal's Avatar
no worries
