07-24-2019, 09:53 PM | #1 |
Tilt Column, column shift, auto. The real deal truck tilt. Another another one
This is a nice column. It appears someone has painted the shift bowl and metal shift indicator housing, the remainder appears to be original paint.
Still has the part number sticker on it. So what identifies this as a real truck tilt? Some of these features are on early van tilts and later model motorhome tilts, but real truck tilts have all of the following attributes 1. Small font shift indicator lens 2. Very long grey power wire for shift indicator lamp with black female connector. 3. Truck column grommets and lower metal retainer 4. Straight thin metal stamped lower shift linkage lever. 5. All Black plastic turn signal switch and horn contact 6. Short shaft stickout that attaches to intermediate shaft. 7. Metal shift indicator housing 8. No other holes in middle of column to mount the neutral safety switch. 9. Upper center shaft where steering wheel attaches does not have a groove for retaining ring. 10. Ribbed turn signal and tilt levers. 11. The factory paint finish is gloss black. 12. Tulip style hazard button. 13. Half moon wiring connector on turn signal switch. 14. Amber indicator lamp cover. As you can see this column does not have any noticeable rust, its especially clean at the end where it sticks out into the engine compartment because it came from a motorhome here in the pacific northwest. I wiped off a small area of the shaft and splines which revealed clean metal. $450 shipped which includes a full service and same or next day shipping or $550 shipped including service, complete disassembly bead blasted and painted gloss black. I need 3 days to bead blast and paint. Service includes upper tilt pivot disassembly to verify the tilt pivot knuckle bolts are still tight, clean and lube turn signal switch and tilt pivot pins and detents. Clean and repack upper and lower bearings. |
07-24-2019, 09:57 PM | #2 |
Re: Tilt Column, column shift, auto. The real deal truck tilt. Another another one
Turn signal area is clean without any rust which is so common.
Amber bulb cover is cracked but still does what it needs to do. |
07-31-2019, 07:16 PM | #3 |
Bump for a great seller Randy's steering columns are top notch and beautiful!
07-31-2019, 07:48 PM | #4 |
08-06-2019, 04:11 PM | #5 |
I take trade in tilt columns, pm with what you have.
08-15-2019, 09:57 PM | #6 |
Last chance before i restore this one....
08-18-2019, 07:04 PM | #7 |
Do you still have this column?
08-18-2019, 08:15 PM | #8 |
08-18-2019, 10:19 PM | #9 |
Sold to Cbo68 pending payment and pickup tomorrow.
