Old 07-24-2019, 11:07 PM   #1
lv2tri2
Steering Clearance issues
I know the steering clearance issues with MII and the AD chassis have been discussed here more than once. Now it's my problem and I cannot find an answer. I have some cast Hookers that are a problem both with the steering and the center exhaust outlet being too close the rubber in the motor mount. Is there a good solution with either a factory or after market header.
lv2tri2 is offline   Reply With Quote
Old 07-24-2019, 11:09 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Steering Clearance issues
Just reroute the steering around it with u-joints and dd shaft...not sure about the hookers and motor mount
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-25-2019, 02:25 AM   #3
mr48chev
mr48chev's Avatar
Have you got a decent photo of it on the engine?
My ongoing truck projects:
Old 07-25-2019, 03:52 AM   #4
MiraclePieCo
MiraclePieCo's Avatar
I also learned the hard way that MII and SBC center dumps put the manifold and steering shaft in the same place. 1981 Camaro and Firebird 305 manifolds dump between cylinders 5 and 7, clearing room for the steering shaft. Using these I was able to get my steering shaft to sneak past the manifold by about 1/4-inch with no extra u-joints.
A lot of guys move their steering column to their left also. They report that they can't tell the difference.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 07-25-2019, 08:00 AM   #5
jbarron
The ones used on the ~69 Camaro clear pretty good also.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 07-25-2019, 12:01 PM   #6
mr48chev
mr48chev's Avatar
We are assuming that you have a Gen 1 small block and not an LS with cast Hooker manifolds or a big block. Are we correct?
I spent a half hour looking for the cast hooker header/manifold for Gen 1 engines last night and got skunked. I did find the ones for LS an found some gen 1 from Speedway that they say are discontinued.
Old 07-25-2019, 01:54 PM   #7
lv2tri2
I do have a Gen 1 small block. I believe 1997. I'm not certain of the other possibilities, found while searching. L31, LT1 but I know it is a Truck 2 bolt Vortec. The exhaust manifold is not a Hooker. I bought it new, don't remember where, could have been Ebay. I regret giving little thought to my information. I value the continued input you provide. I am working on the picture you requested.
Old 07-25-2019, 06:30 PM   #8
lv2tri2
Thanks for your help. I forgot to include that my engine is a Vortec and with that I'm not sure the older Camaro manifolds work. I will look at one closer.
Old 07-25-2019, 06:31 PM   #9
lv2tri2
Thanks, I will check the older Camaros.
Old 07-25-2019, 07:33 PM   #10
starterman99
starterman99's Avatar
I am trying the Dorman #674-197 on my 1950 with c4 Vette rack
1950 5 window
starterman99 is offline   Reply With Quote
Old 07-25-2019, 08:44 PM   #11
lv2tri2
Red face Re: Steering Clearance issues
I'm not in a hurry, I'll wait to see how the Dorman's manifold works for you.
Old 07-25-2019, 10:25 PM   #12
Livemeyer
Livemeyer's Avatar
My truck came to me this way. I think it odd, but I don't know how it affects the steering geometry at all. Mine has a 2 or 3-inch plate steel welded to the outside of the frame, with bolts in the top and long bolts traversing under the weld plate and through the firewall. I have no idea if it is safe, but until I get IFS installed, it will have to do.
Livemeyer is offline   Reply With Quote
Old 07-29-2019, 04:05 PM   #13
jweb
jweb's Avatar
Usually a manifold that dumps at the rear works the best for the drivers side. I don't know if this would work on you, when I had a 350 sbc in my truck an early 80's manifold worked perfect. It went inward right where the steering shaft was.
It looked like this https://www.1aauto.com/chevy-gmc-bui...iABEgIFVfD_BwE
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 07-29-2019, 08:50 PM   #14
lv2tri2
Thanks JWeb, I will look at these.
