Old 07-24-2019, 11:46 PM   #1
Simple10
Simple10's Avatar
Coil suspension
Hey guys I just had my C 10 lower , rear springs, and it is sitting lower on one side can anyone confirm if there is a left and right? People that did it said there isn’t but the experts down the road “specialists” apparently said there is a left and right spring on rears.... it’s going back this weekend to see what the problem is.
The left looks to be fine sitting flush but the right seems to not sit so flush, would this be causing the issue, see pics, they told me they would get a spacer made up and put in it I said no im not keen on that idea it came in level it’s coming out level.
Thoughts?
Simple10 is offline   Reply With Quote
Old 07-25-2019, 04:35 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Coil suspension
Ha... never heard of left and right springs...how bad out of level does the truck sit?...spring spacers arnt a big deal but if you used new springs you shouldn't need them...some better pics of how it's all installed may give a clue
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-25-2019, 06:46 AM   #3
PGSigns
PGSigns's Avatar
Re: Coil suspension
Did you have the front springs changed? They have been known not to seat in the top correctly. How much have you drove it? The springs will settle in and level up some over the first several 100 miles. Did you have any other work done?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-25-2019, 07:58 AM   #4
Simple10
Simple10's Avatar
Re: Coil suspension
To hard to tell from pictures, left hand rear sits lower, only the rear was lowered
The front is only about an Inch off the bump stops now.
Old 07-25-2019, 08:27 AM   #5
Stormin08
Stormin08's Avatar
Re: Coil suspension
can they be rotated ?
Stormin08 is offline   Reply With Quote
Old 07-25-2019, 12:11 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Coil suspension
Rotate the rear springs where they both contact the trailing arm in the same spot.
It looks like in your pics, the right spring contacts the trailing arm on the front side of the spring,... and the left side on the rear of the spring.
That's the best that you can do, since the springs are the same.
Keith
Convert to disc brakes.
Old 07-25-2019, 06:56 PM   #7
Simple10
Simple10's Avatar
Re: Coil suspension
I’ll give it a go tomorrow
Old 07-26-2019, 08:57 PM   #8
Simple10
Simple10's Avatar
Re: Coil suspension
All sorted. Apparently when they lifted the front the front right hand spring came unseated which made the left rear lower drop, all seated all good.
Old 07-26-2019, 10:35 PM   #9
mongocanfly
Post Whore
Re: Coil suspension
Great..!!...nice looking red truck ya got there....
Mongo...aka Greg
RIP Dad
RIP Jesse
