Old 07-25-2019, 11:38 AM   #1
ScottH
ScottH's Avatar
Exclamation Problem with upper ebrake cable anchoring
Recently installed all new brake cables in my 65 c10. All works good except the upper cable will not anchor securely in the clamp that holds it just below the pull handle. No matter how much I tighten the bolt, it slips through when I pull on the handle. The rubber coating is getting shreaded from slipping in the clamp.
Has anyone run into this issue & found a solution?
Any info, suggestions, or help is greatly appreciated.
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 07-25-2019, 05:46 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Problem with upper ebrake cable anchoring
I had that same problem several years ago, mine broke so I tried about 4 or 5 new rep pops....nothing worked, so I found an nOS on eBay and paid way to much but it worked! Oh, I also changed from the 65 to 66 ebrake setup also.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-25-2019, 11:44 PM   #3
ScottH
ScottH's Avatar
thanks clyde, appreciate the info
Old 07-26-2019, 07:05 PM   #4
rvrfoot
My 66c10 was a long bed. When I cut it the kit came with a new cable.
rvrfoot is offline   Reply With Quote
