Old 07-25-2019, 08:56 PM   #1
Curtb1971
Curtb1971's Avatar
MAF sensor location
Hey there, I'm wondering if there is a certain min/max distance the mass air flow sensor needs to be mounted from the throttle body. I'm running a 2008 truck base and a ls3 style MAF. Just wanting to make sure I did or didn't put this in an ok spot. Thanks, Curt
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 07-25-2019, 08:59 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: MAF sensor location
My early styles are real close to the throttle and I've had no issues...my LS3 one has yet to be mounted.
So I'm not sure on it
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-27-2019, 10:05 PM   #3
lutronjim
My 'connect and cruise' LC9 engine wanted the MAF censor centered within a straight 4" diameter pipe of at least 12". It also had to be some distance from the throttle body which I can't remember.
I had bought an aftermarket 3 1/2 chrome pipe that was curved with boss on ebay - I figured that was good enough. Wrong - it kept throwing codes - finally bought some 4" aluminum pipe and connectors and made my own. Codes went away and runs great.
However I have seen many different configs that apparently run ok.
I can take some pics if you want
lutronjim is offline   Reply With Quote
Old 07-28-2019, 01:43 PM   #4
Curtb1971
Curtb1971's Avatar
Thanks Greg, keep us posted when you get yours installed
Thank you, I'm not throwing any codes but haven't had a fine tune yet. I guess I'll know for sure if its location will work when we get some data uploaded.
Old 07-29-2019, 12:15 AM   #5
AZ 67 C10
AZ 67 C10's Avatar
There is a thread or posts somewhere in the ls swap section about MAF location and issues related to it being in the "wrong" location. Seems like it can be hit or miss as far as having issues with location, but i've also heard having it within a straight 4" diameter pipe of at least 12" is ideal.
1967 C10 SWB 6.0 LS swap in progress
2011 CCSB Duramax 4x4
AZ 67 C10 is offline   Reply With Quote
Old 07-29-2019, 01:03 AM   #6
siggyfreud
siggyfreud's Avatar
Makes sense it would need to be in a certain spot, as they're essentially having to calculate when THAT air being measured by the MAF will be in the cylinder. Too long and you get the fuel too early, too short, and you get the fuel too late.
siggyfreud is offline   Reply With Quote
Old 07-29-2019, 09:36 AM   #7
lutronjim
Here is pic of mine. The cross flow enabled me to go across radiator to driver side.
Another thing documentation said was to mount maf at 12 oclock on tube. I had to fudge a little to keep cable from hitting hood.
I put a 90 on end going down to filter with fresh air hole cut through to grill. .
Old 07-30-2019, 02:04 AM   #8
Curtb1971
Curtb1971's Avatar
Thanks guys, I think mine is in the wrong spot. I ran the truck with maf hooked up and it spit and studered in higher rpms. Disconnected maf and ran in speed density and it came alive. Need to come up with a better intake tube and try again with mounting the maf. Sorry about the first pic being rough on the neck
Old 07-30-2019, 03:31 PM   #9
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
You probably dont need a better intake tube, you need to calibrate your maf to the intake you have. I had problems using the universal maf housing which was a different diameter than stock gen5... idled poorly, long term fuel trims maxing out, timing retarding... hptuner forum pointed me to fix the maf calibration, I did and runs great now.
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-30-2019, 05:18 PM   #10
First c10
First c10's Avatar
Clint
I agree with 87chevy!!!
If you don't have access to re-calibration of MAF you will need to find out what the MAF and intake tube size is that your ECM was originally programmed and try and replicate it!!!
My sons truck had a 3-5/8" intake originally and when I put a 4" it did what you described. fuel trims out of wack and didn't idle or run well. Put a reducer around the MAF from Spectra to the stock size and everything went back to normal like flipping a switch.
Good luck and let us know what you do!
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
