Old 07-26-2019, 08:36 PM   #1
Matt_50
Coolant reservoir
I need a coolant reservoir and I was looking at universal ones and some looks a lot like the washer fluid bottle off my donor.
Can I use it? Does size matter? Or... What do you recommend?
I have a couple spots it'll fit.
And factory; was it a bottle shaped thing going along the radiator sides?
1950 Build
Matt_50 is offline   Reply With Quote
Old 07-26-2019, 09:00 PM   #2
jmlloar
jmlloar's Avatar
Re: Coolant reservoir
pretty much anything will work long as you make sure hose goes to the bottom so it can pick up coolant as it cools off.
I have used antifreeze jugs as a makeshift one in the past. make sure its not airtight and you will be fine.
any universal one will work.
jmlloar is offline   Reply With Quote
Old 07-26-2019, 10:03 PM   #3
Matt_50
The hose does go to bottom and it's just a pop on lid, so I guess I'm good.
Thanks!
1950 Build
Old 07-26-2019, 10:23 PM   #4
Fast Chevy
I found one I liked at salvage yard, cheap and almost any size , shape u can think of. I paid less than $10, just had to look under a few hoods.
Jeff
Fast Chevy is offline   Reply With Quote
Old 07-26-2019, 11:08 PM   #5
mr48chev
mr48chev's Avatar
That might function as one.
Originally they didn't have them at all and the hose just ran down below the bottom of the radiator and if it puked it puked on the ground. That is all kinds of wrong today for no more reason than you don't want to be poisoning an animal because your truck puked a puddle of antifreeze.
The main bad thing about that tank besides serious ugly is that the fitting for the hose is too small in comparison to the fitting on the radiator.
My ongoing truck projects:
Old 07-26-2019, 11:16 PM   #6
Matt_50
Lmao, yes seriously ugly! That does scrub off pretty good. I have seen some cylindrical types that I thought would look good.
Yea, the fittings are a little off but ID is the same.
1950 Build
Old 07-27-2019, 01:40 AM   #7
MiraclePieCo
MiraclePieCo's Avatar
I have a collection of plastic step-down adapters from NAPA for just such occasions.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 07-27-2019, 11:05 AM   #8
vintovka
vintovka's Avatar
I found one that is narrow and fits to the side. Had to raise it up to nearly level of top rad tank for it to work properly btw. Now it works great with no issues. Will post a pic soon
vintovka is offline   Reply With Quote
Old 07-27-2019, 12:50 PM   #9
_Ogre
_Ogre's Avatar
i used a piece of 3" ss exhaust tube to make my tank
shop air compressor timer
Old 07-27-2019, 06:14 PM   #10
Black_Sheep
Black_Sheep's Avatar
I found a decent catch can at a swap meet, it fits nicely on the core support between the radiator and fender. I epoxied a long piece of 3/8 steel line into the fitting on top to convert it to a coolant recovery system.
Black_Sheep is offline   Reply With Quote
Old 07-30-2019, 03:29 PM   #11
Matt_50
I couldn't find a decent spot for the tank I have so I started googling the cylinder types.
Some of what I'm finding have screw on lids. But are these tanks supposed to be airtight or does it matter?
1950 Build
Old 07-30-2019, 04:06 PM   #12
_Ogre
_Ogre's Avatar
you can't use air tight, it needs to vent to fill or drain back
my vent/overflow is a tube welded in the bottom that goes almost to the top inside
my tank holds roughly 65 oz
Old 07-30-2019, 04:08 PM   #13
Matt_50
Is it vented on top? On other side in picture?
Ok so no screw on lids.
1950 Build
Old 08-01-2019, 01:27 PM   #14
_Ogre
_Ogre's Avatar
vented on top would also spray coolant out of the top
as stated my vent tube comes out of the bottom and is bent to prevent coolant overflow from hitting the frame
Old 08-02-2019, 10:20 AM   #15
dsraven
check dorman oe solutions. maybe something like this would work. lid properly labelled and cheap too.
https://www.amazon.com/Dorman-603-00...PAYSMRVJRVCGNK
Old 08-09-2019, 07:04 PM   #16
Russell Ashley
Russell Ashley's Avatar
The good thing about buying a factory overflow tank from the junk yard is that they have the fluid level marked and are transparent enough that you can see the level. They are also rugged enough to take the hot fluid with out melting. I got one for $5 at Pull-a-Part. Just look until you find the size and shape you want.
Russell Ashley is offline   Reply With Quote
Old 08-09-2019, 08:19 PM   #17
MiraclePieCo
In my continuing quest to simplify, I do it the 1960's way: no overflow tank, just the puke tube down the side of the radiator that vents onto the ground. It's never actually puked anything yet.
Old 08-12-2019, 01:32 PM   #18
gigamanx
Anything works. I prefer emptying an alcohol bottle while doing other projects then using the empty for the truck
I just drilled a hole in the cork top and stuck a tube to the bottom. Welded up a bracket to hold the bottle.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
