Old 12-01-2003, 01:11 PM   #1
Jason71k10
ready for reassembly
Jason71k10's Avatar
205 grinds in 4-low?
I have a 350/350/205 set-up in my 71. I noticed last week while playing in the mud at work that 4- low grinds really bad.....but it stilled moved though. 4-high and 2-high work fine.
Is this t-case a timebomb, or should it be okay. I put very few miles on it by the way. Should I be worried??? Thanks guys
Jason
stock 71 4x4
2003 Jeep Liberty, rocky mountain edition
I'm obsessed, and wouldn't have it any other way!
Jason71k10 is offline   Reply With Quote
Old 12-01-2003, 07:49 PM   #2
Jason71k10
Jason71k10's Avatar
anyone?
stock 71 4x4
Old 12-01-2003, 08:26 PM   #3
Scrub
Collector of rusty Items
Scrub's Avatar
When does it grind? All the time, When you are moving on pavement, When you are moving in mud.
My first inclination would be to suggest that your linkage is not allowing the 4wd to engage all the way and the grinding is when the rear wheels are spinning and the front are not because the t-case is only half way into 4wd.
Wash the mud off and crawl under there and have someone put the tcase in 4LO. If you can jack up all 4 wheels, you might learn more. Please use big firewood blocks if you are gonna be under there when the rig is spinning wheels. Try applying the brakes to simulate a load.
Let us know what you find
Good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 12-01-2003, 10:53 PM   #4
Jason71k10
Jason71k10's Avatar
I never thought of it not being fully engaged?... I did notice during the summer, I was towing my dad's truck and fifth wheel up the driveway(long story) when I put it in four low, it didn't grind, but the front wheels wouldn't turn either. Yet it worked fine in 4-high. btw, i wasn't doing any hardcore mudding, it was just 4-5" of mud around the jobsite.
stock 71 4x4
