timken bearings in napa's pre-installed rotor race?
I bought a new front brake rotor for my 71 C10.. (part number 4885537). I pulled it out of the box to put in the races for my new Timken bearings, but saw that the rotor comes with races pre-installed.
My question is, would the timken bearings be fine dropped in with those races, or do I need to hammer those out and put in the races that came with my bearings? Last edited by turpentyne; 07-27-2019 at 07:06 PM. |
![]() Join Date: Dec 2009
Re: timken bearings in napa's pre-installed rotor race?
I would not.
Keeping a long story short. The bearing and race in the box are a matching set. There from the same company (same production Run). The race in the hub could be SKF , NSK or ?. Just my Opinion. And you know what that's worth. .
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
I don't know of a good way to determine if the tapers are the same. I've always replaced the cups if the part didn't come with the cone. It's a little more work, but unless you are rock solid certain that the parts match, it's a gamble.
Like Getter-Done says, pop the cups in there out and put in the known matching ones.
Third opinion: same as the previous two. I would say you'd be OK 95% of the time with the match. It's the other 5% that I'd worry about, and why worry when you have the solution in hand?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson 1972 K/5 Blazer CST 4WD 1963 Corvair Monza Spyder Turbo convertible 1995 Camaro Z/28 |
Yeah... I figured better safe than sorry. Hammered 'em out and put in the timkens.
Managed to not gouge anything with the drift, so all's well that ends well! EDIT: for anyone interested, the races that were in there don't have a brand labeled on them. but part numbers are stamped: M12610 and LM48510. Got the rotor at NAPA. Not sure if that's some universal part number, but a google search comes up with Timken... what luck... hammered out brand new Timkens, so I could put in brand new timkens! Per @Getter-Done's comment, probably was still a good idea, having been from probably a different production run Last edited by turpentyne; 07-27-2019 at 09:01 PM. |
At the body shop.
Rotors for my 98 crewcab came with races and studs.
Been a year so far. No issues yet
" That didnt make it any newer " " Dont antique the equipment " |
![]() ![]() Join Date: Feb 2009
I did this the first time recently, the races come out easy. As others suggest match up your bearings & races. Take your time and use a flat nose chisel of some sort to punch them out, you don't wanna ding up your rotor. I picked up a bearing/race/seal driver kit for cheap off Ebay or something like, they're worth the money. Grease and pound the new races in, easy once done.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
| Bookmarks |
