07-27-2019, 11:24 PM | #1 |
Body mount kit from Classic Heartbeat
I bought the kit last week and got it installed today. I'm glad I got the full kit with all the hardware because out of the 6 i replaced I maybe could have reused 1 of the bolts.
No surprises once I got the old rusty ones off. The new ones went right on. Very good kit as far as I can tell. It's not as tough of a job as I thought. If you've been dreading it like I was, just get it done. |
07-27-2019, 11:57 PM | #2 |
70+ ( Old Skool Club )
Re: Body mount kit from Classic Heartbeat
Is your truck, running, driving ?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-28-2019, 12:48 AM | #3 |
I still have to fit a rocker, then line up a fender before it's back on the road. I wanted to get this part handled before that.
Is there something I should look out for? |
07-28-2019, 12:54 AM | #4 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-28-2019, 12:29 PM | #5 |
I did this on my 1970 C10 yesterday, got inspired by I think it was Grumpy's "How To"
I thought Classic Part's (Kansas City) Cab Mount kit was a good option too - only $60 and everything you need in one box (see photos). Noticed that those upper cushions are very close to the same exact size as a standard hockey puck - so much so I was tempted to try them but not this time.. |
08-05-2019, 08:52 PM | #6 |
Say Southpaw, did you end up using any shims? Classics kit doesn't come with any.
I see some kits come with one (or two) for each mount. For what it's worth my factory front mounts used an 1/8" shims on all four corners. The fronts used the square shim like you see in some kits.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-09-2019 at 09:31 PM. Reason: Corrected |
08-05-2019, 10:09 PM | #7 |
Did you do radiator support also?
08-05-2019, 11:50 PM | #8 |
Can you change the body mounts out on a running /driving truck. Like remove one replace it , and so on and so forth?
08-06-2019, 01:05 PM | #9 |
I wouldn't cuz you'll get run over (just kidding). I've never done it, but I hear a floor jack is all that's required. Sounds like you don't have to disconnect anything.
08-07-2019, 12:21 AM | #10 | |||
08-07-2019, 01:51 PM | #11 | |
at least that's what I did on my C20.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
08-09-2019, 08:52 PM | #12 |
I was wrong saying my rear cab mounts didn't use shims. I must have thought the washer was integrated with the cushion.
Based on conversations, and feel free to correct, unless the truck calls for them it's OK if shims aren't used. In other terms, it's OK the cab braces sit directly on the top cushions. Hopefully I'm on the right track, we sit the cab tomorrow. Here's what was included with my kit against the original mounts.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-09-2019 at 09:36 PM. |
08-09-2019, 09:50 PM | #13 |
Buy the kit from Classic Chevy truck parts it's rubber like the originals (they have urethane if you like squeaking ) they cost less and have the extra shims . I use Classic parts for a lot of the small parts .
https://www.classicparts.com/1967-72...nfo/35%2D145/# All the necessary original rubber cushions, steel bushings, washers, bolts, nuts and shims for mounting cab to frame.
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-09-2019, 11:28 PM | #14 |
I'm rethinking this, and surely overthinking it
I tend to think shims are required to flush and square things up. But I believe the original "shims" are more than that, perhaps even necessary, at least at the rear. Reason is the top cushions have a wider base than the cab braces, and the rear shims are near a perfect fit on top of the rear cushions for a complete platform. But I don't believe Classic Heartbeat's cushions require them. In fact a "bird" told me the "shims" are optional, front and back The center area on the rear replacement cushions are much harder than original. Both sides of the replacement top front cushions are hard, while the original cushion used a steel washer-plate on both sides. Perhaps the rear shim was a must on the old set-up, and the front shim optional. I'll ask the body/paint guys when they show to mount this tomorrow. In a pinch I can reuse my old "shims", front and back. I may have all the hardware black zinc plated for finish. On a side, that zinc plating is tough. I took a BFH to the fronts already black zinc, and it didn't leave a mark.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-10-2019 at 01:01 AM. |
08-10-2019, 12:23 AM | #15 |
I'll stick with Wes.
08-11-2019, 10:25 PM | #16 |
I might recommend large washers for Heartbeat's kit, placed below the lower core support cushions. The cushion squeezed off the supplied washer long before I hit "the minimum" torque setting of 35 ft. lbs. $1.50 at the local in a pinch.
This may be a case you just don't torque Heartbeat's cushions down much. That said, we hit the common minimum (35/70/35 ft. lbs.) on all six mounts. The cushions look real good, and do appear high quality.
01-26-2020, 10:44 AM | #17 |
As soon as I finish putting on new rear leaf spring bushings I plan on replacing all the body mounts (kit in hand from Classic Heartbeat). My question: Is there a certain order of install that should be performed to limit tweaking the body / throwing off your body lines? (front to back, back to front, left side then right side, etc.) My brother says that you should start with drivers side radiator cushion, then the passenger side and then onto the cab mounts under the carpet and finally ending up at the rear (again using the drivers side first and then the passenger side next). His logic is that if you replace starting in the rear cab and move forward to the radiator cushion you're putting stress on the front end as you're putting new mounts on the cab (the front is pulling down because the cab cushions are now higher. What is everyone else doing?
Ron 1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White |
