Neutral safety switch wrench
Well i was struggling with getting the neutral safety switch adjusted due to having a hard time getting anything to fit in the tight spot. I did as everyone said and grabbed a 1/4 in socket and the smallest head ratchet i had but in the 90 deg temps today i struggled and decided there had to be a better way. I ended up grabing a cheap -o- 1/4 inch nut driver out of a set i bought at a wrecking yard to pull some trim and went to work with the grinder a vise and a pipe to bend the shaft. I ended up wrapping the end with electrical tape for a better grip. It works great and will go in my tool box for future use. Simple...cheap and works.
