07-28-2019, 08:47 PM | #1 |
6 cylinder block side motor mounts
Looking for the brackets that bolt onto the block, putting a 250 into a 68. Have the frame side mounts just cant find the other ones anywhere.
07-28-2019, 09:44 PM | #2 |
Re: 6 cylinder block side motor mounts
250 motor mounts didn't used to be that hard to find. They're the same unit on both sides. Unlike the bigger L6, the 292, which has a different mount on the Passenger Side than the Driver Side.
If you paid $25 for a premium membership, you could place a WTB [want to buy] ad in the classifieds on this site. Part of the scarcity problem, is the way a lot of guys up-gunning to a V8, think ''no one will ever want this L6 stuff'' and just chuck it. But that's life. You might also check the bulletin boards over at www.inliners.org That's the site of the Inliners International Club. A group that meets to advance and promote the inline engine in its many forms: -4, -6 and -8 cylinders in line.
07-29-2019, 09:10 AM | #3 |
Scrapper 1
I looked for them for over 5 years after i bought a really clean 1969 nova 250 motor But after 5 years of not finding any i sold the inline 6
07-29-2019, 11:43 AM | #4 | |
Best of luck with your search OP.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
07-29-2019, 01:18 PM | #5 |
I have a few extra sets , I'll dig them out and list them in the parts section .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-29-2019, 02:27 PM | #6 |
I believe someone is making an aftermarket 292 set of motor mounts. [For unheard-of money] The only downside [after the price] is that they require mounting to the Fuel Pump receiver on the Passenger Side, and converting to an electric fuel pump. While making for a symmetrical set of motor mounts like the 230/250 L6s -- the reason GM engineered the offset mounting on the 292 was to counteract its massive torque.
I don't know if the same company is also making a 250 mount set. [Since the Driver Side is the same as the Passenger Side, reversed. It wouldn't be hard.] For the price of the 292 set, modifying it for a 250 would be impractical.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-29-2019 at 02:33 PM. |
07-29-2019, 08:26 PM | #7 |
I happen to think they are cool engines, cleaned up and few extra parts they look awesome.
07-30-2019, 02:08 AM | #8 |
Tom Lowe at www.12bolt.com has a new design L6 motor mount set that fits stock GM V8 style rubber pads. A set for the 250 runs $100.
