Old 07-28-2019, 09:20 PM   #1
randy500
Tilt Column, column shift auto, motorhome conversion
These motorhome columns have the short inner shaft stick out that is the same as a truck so no modifications are needed to the intermediate shaft and they are a true bolt in.
The motorhome shift arm has a dogleg in it which doesn't affect how it shifts, its just different looking.
I completely disassembled this and moved the neutral safety switch to the truck location.
It was bead blasted primed and painted gloss black.
It has a new lower grommet and retainer, the upper grommet is nice used. The turn signal lever and tilt lever are new.
Shifter pin hole is nice and tight.
Turn signal switch was disassembled, cleaned and lubed.
All parts were inspected lubed and set to factory specs
$429 shipped. .
randy500 is offline   Reply With Quote
Old 07-28-2019, 09:21 PM   #2
randy500
Re: Tilt Column, column shift auto, motorhome conversion
Couple more photos
Old 08-02-2019, 02:55 PM   #3
randy500
Beautiful column.
Old 08-06-2019, 04:09 PM   #4
randy500
Ttt
Old 08-12-2019, 07:39 PM   #5
randy500
Ttt
Old 08-13-2019, 08:58 PM   #6
Boog
laying low
Boog's Avatar
Randy is the metal wiring cover from a non tilt column the same as one for a tilt column? I see there is no cover on that column.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-13-2019, 09:00 PM   #7
randy500
No they are not the same, i will include one with this column, i can take one off another column.
Old 08-13-2019, 09:23 PM   #8
Boog
laying low
Boog's Avatar
Ok. Will you accept a postal money order?
Boog
primer is finer
Old 08-13-2019, 09:38 PM   #9
randy500
Thats fine, sending you a pm now.
Old 08-27-2019, 11:47 AM   #10
Boog
laying low
Boog's Avatar
Bump
The package arrived today.
Boog
primer is finer
Old 08-27-2019, 11:48 AM   #11
randy500
Great, Good to hear that.
Old 08-27-2019, 01:58 PM   #12
Boog
laying low
Boog's Avatar
Randy were the levers not included ? I didn’t see them in the box.
Boog
primer is finer
Old 08-27-2019, 02:02 PM   #13
randy500
Should have been wrapped up with the shifter arm and horn contact, wrapped around the center lower part of the column.
