Old 07-28-2019, 09:35 PM   #1
Mattchu60
LS swap initial break in done, should I keep using break in oil?
I got my 5.3 swap completed over the weekend, freshly rebuilt 5.3, bored .030 over. Of course it has a roller cam, but I used break in oil anyways. I've driven it around 30 miles after the initial break in, and I want to change the oil for fresh stuff. I'll keep using regular dino oil (non-syn) for the first 5,000 miles. My question is simple - should i keep adding the Lucas break in oil to the engine or is it not needed at this point?
Mattchu60 is offline   Reply With Quote
Old 07-28-2019, 11:37 PM   #2
prodjay10
From what I understand, it’s not necessary but the break in oil is supposed to provide better protection. Downside is that it is more expensive.
prodjay10 is offline   Reply With Quote
Old 07-29-2019, 12:26 PM   #3
siggyfreud
siggyfreud's Avatar
Re: LS swap initial break in done, should I keep using break in oil?
Did you use assembly lube in all the right spots? Did you follow an engine break-in process? If it were me and engine break-in was complete I'd just keep using conventional oil for the first thousand miles, and then switch it over the synthetic.
I probably wouldn't continue using break-in oil. If you did the break-in process already your rings should be seated. Outside of that, you don't really have many wear-items in there relative to a non-roller setup.
siggyfreud is offline   Reply With Quote
Old 07-29-2019, 04:52 PM   #4
sweetk30
sweetk30's Avatar
i run bradpenn breakin oil on my gm long block L31 for 500 miles and she come out good color and since then its been mobil 1 5-30 and no problems . good pressure and no real loss of oil .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 07-30-2019, 11:23 AM   #5
Mattchu60
Thank you for the replies. I did end up using break in oil again, but after this round I think I will just use conventional oil only until about 5,000 miles.
