Old 07-29-2019, 10:12 PM   #1
slammed57
slammed57's Avatar
wood floor
some folks are installing the wood on top of the wood angle supports.(pics below) looking for the pros and cons if i was to do this... the floor will not lift up on hinges it will be permanently attached.
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 07-30-2019, 08:05 AM   #2
jbarron
Re: wood floor
Main issue I see is at the tailgate there will be a lip.
I doubt that bed will ever carry anything.
It would give you 1" of extra clearance underneath.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 07-30-2019, 08:06 AM   #3
jbarron
Re: wood floor
They may not have installed the bed strips in this case or moved them.
Old 07-30-2019, 02:20 PM   #4
b-mac
b-mac's Avatar
Re: wood floor
Some of the bed floor manufacturers are offering a different kind of SS strip too. One that is more recessed. That may be the case here.
b-mac is offline   Reply With Quote
Old 07-30-2019, 03:28 PM   #5
_Ogre
_Ogre's Avatar
Re: wood floor
other than the rear rail, the only support for the bed is sitting on the wood
you'd need to redesign the bed mounts to support the bed sides
my angle strips were rusty and in need of replacing, i welded in new 1.25"x1.25"x1/8" steel angle
my wheel tubs are cut outs from the bed sides
trex plastic decking for bed 'wood'
shop air compressor timer
Old 09-11-2019, 03:28 AM   #6
jocww
Re: wood floor
looks very nice og
My build a 49 5 window ls1 4l60e on a TCI chassis
http://67-72chevytrucks.com/vboard/s...d.php?t=754926
My travel blog
The Wong Winding Road-Adventures of The Chinese Cowboy
https://thewongwindingroad.blogspot.com/
jocww is offline   Reply With Quote
Old 09-12-2019, 09:15 AM   #7
my56chevytruck
my56chevytruck's Avatar
Re: wood floor
As usual, nice work my friend!!
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
