Conversion axle install; any tips?
70 swb
75" between backing -Have the 6 to 5 axles coming this week from EC. I have never swapped axles before. I cant find any 67-72 specific axle conversion 'how to' videos. Is there any special tools I will need? Will I need (*or should) to replace the differential fluid, if so what weight and how much will I need? Can anyone point me to a 'good' video of the axle swap? (too many 'how to' vids done with bad info. I cant tell if one is good or not!) OR a site with a 'how to' pictorial. Thanks for any advice! |
![]() Join Date: Feb 2002
Re: Conversion axle install; any tips?
There's a video on You Tube by Sappers House, called ''GM12 Bolt. Removing the Axle''
https://www.youtube.com/watch?v=P80vg9eBouQ You will want about a gallon of SAE 90 weight gear oil, service GL-4 if not a Posi and GL-5 if Posi. You don't re-use gear oil.
