![]() Join Date: Jul 2016
Parting 72 k20 chassis
I am using the following
Engine and trans crossmembers Front spring mounts Steering gear box For sale: Frame cuts or mounts, from $35 shipped and up. Front and rear axles, dana 44 front, HO52 or 72 rear both with 4:56 gears or any parts from them New front 6” lift springs with rear blocks and u bolts front and rear, $250 local, can ship, estimate shipping at $150 Other crossmembers, bed mounts, rear spring mounts, etc. Pictures coming. |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Parting 72 k20 chassis
Any clips for harness, fuel lines, brake lines I'd be interested in please.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Carpe manana
Thanks, I don't have a specific need at this time.
#5 | |
![]() Join Date: Nov 2018
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
Is the rear a "no-spin"? If so I'll consider paying shipping.
![]() Join Date: Dec 2015
Exhaust hangers?
The front springs fit K10 and k20, superlift brand 6” lift
Just letting you know any locker will work from any gearset as you can take the spiders out and swap the locker, it’s how my 4.56 locker because a 410 locker
#13 |
Does the no spin act like an eaton so both wheels turn or is it like a govlock and you cant tell unless you remove the cover
#14 |
![]() Join Date: Mar 2013
What about the rear cab mounts both sides shipped to 28034
#15 |
One of the First
![]() Join Date: Jan 2000
What does the rear shock mounts look like?
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#16 |
#17 |
#18 |
You should have the money via PayPal for the rear cab mounts. Will PM my info.
THanks |
#19 | |
Thanks for the info Madkidd, I didn't consider swapping the spiders out. |
#20 |
I text randy and told him how to tell. What he has is open. A no-spin locker will actually rotate freely, but if you spin it with any speed it’ll lock. By any speed I mean spin it quick by hand and it’ll engage.
#21 |
#22 |
One of the First
If they are not rusting out or bent, burn the rivet heads off the frame, Ill take them if priced accordingly.
#23 |
Randy, what would you charge for the cross member that sits directly above the front of the rear leaf spring mounts, along with both back frame stubs atleast up to the first rear cross member. Shipped to 44234
I'm entertaining having the parts to put my k20 back to stock someday if I ever want. The aforementioned parts were modified to make it a dump bed. |
#24 | |
#25 |
Pictures, passenger side then drivers side. $75 shipped for the pair.
