Old 07-30-2019, 05:38 PM   #1
bigmac73
bigmac73's Avatar
kick panel vents
should I permanently seal up my kick panel vents?
I never use them...
and what is the best way
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 07-30-2019, 05:49 PM   #2
un4gvn!
un4gvn!'s Avatar
Re: kick panel vents
If you don't need them, install 6x9 speakers in them.
un4gvn! is offline   Reply With Quote
Old 07-30-2019, 05:50 PM   #3
MDPotter
MDPotter's Avatar
I sealed mine up since I'm not going to use them anymore. I actually peeled back the outer skin of the cowl and cut a piece of sheet metal and spot welded it to the flange - see my build for clarification. You'll still see the vent from the inside, but you can use that space for speakers too. I am planning on sealing it up from the inside with seam sealer. Also install the cowl screens so you don't get a bunch of leaves and trash built up at the ends of the cowl.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 07-31-2019, 07:30 AM   #4
bigmac73
bigmac73's Avatar
i was thinking about sealing them up and then using the kick panel speakers I got .
so i will probably just have the body shop fab in a piece of sheet metal while it is there and seal them up
Mike
