Old 12-01-2003, 04:05 PM   #1
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Lowering Questions
I plan to lower my truck a little in the very near future. I plan to go with the 2.5 inch Western Chassis spindles to make sure that I don't have clearance problems with my Rally wheels. I have heard from several sources that the DJM 3 inch spindles will require me to modify the control arm, which I don’t want to do.
Everything I read says that the rear is supposed to be 2 inches higher than the front, and that a 2.5/4 kit will give it about ½ inch of rake. I have new front springs with just 200 or 300 miles on them. They have been in the truck for about 6 months while I was doing some work on it. The truck sits almost level, nowhere close to 2 inches lower.
Are the springs settled in yet? If they won't drop much from here, I 'm afraid a 4 inch drop in the back will take it down lower than the front. If I get the Western Chassis 2.5/4 kit, can the height of the back be adjusted?
Where is a good place to buy the kit? The prices at www.sporttruckdirect.com seems reasonable, but they don’t mention shipping costs. I have emailed them 3 times over the last year asking about shipping charges, and they have never responded. They don’t seem to want my money very badly…
Summit advertises that they sell a Summit branded 2.5 inch set of spindles for about $220, and their shipping is very reasonable. Are their store branded spindles Western chassis?
Does anyone have any other recommendations regarding vendors? About what do they get with shipping for the Western Chassis spindles and hanger/shackle kit?
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 12-01-2003, 07:52 PM   #2
78chevstepside
78chevstepside's Avatar
On my 78 i have a 4/6 drop with a c-notched frame . I run 235 60 r15 on the front with a about a 1/2 wheel spacer on rally wheels. I had to grind down the a-arm lip(really no big deal more then once). i also had to use flat wheel weights(mount on the inside base of the wheel)( regular wheels weights would rub if mounted the weights on the inside of the wheel). My wheels still rub slightly if i turn sharp .On the rear have (it dont mattter on the rear) 275 60r15 tires. Before it was lowered i had 275 60s on the front which were new( less then 2 thousand miles). they were not going to work so i bought the 235s. Well i now want to go to 20inch wheels with low profile tires that would solve all my problems(rubbing on the a-arm and wheel weights). If i only knew this before i bought all these tires. I had a shop lower it for me (I was working 7-12s at the time.) I did weld the frame on the c-notch. I think i have a bell teck lowering kit. with a 4/6 drop my truck rides level.
78chevstepside is offline   Reply With Quote
Old 12-01-2003, 07:53 PM   #3
78chevstepside
:p
Old 12-01-2003, 07:55 PM   #4
78chevstepside
Old 12-01-2003, 07:56 PM   #5
78chevstepside
Old 12-01-2003, 08:00 PM   #6
78chevstepside
actually i like playing with my new toy the digitial camera
Old 12-01-2003, 11:24 PM   #7
BaggedC10
Under construction!
BaggedC10's Avatar
Originally posted by 78chevstepside
You need shock extenders!
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 12-01-2003, 11:47 PM   #8
BaggedC10
Under construction!
BaggedC10's Avatar
1. I had a 3/4" drop and would estimate 1.5" of rake. I used Belltech spindles and Smooth-Rider leaf springs. It rode awesome on the highway but bottomed-out allot on rough roads.
2. It sounds like your springs have not settled up front.
3. If you use the standard shackle/hanger kit, the height can be adjusted. I don't believe Western Chassis hangers are adjustable like DJM units though.
4. I've dealt w/ Sport Truck Direct many times and would recommend them. www.PerformanceSuspension.com also offers WC products. "Swervin Ervin" has done business w/ them several times.
5. I believe the Summit Racing products are actually WC components. I'm not sure though.....
I would recommend DJM 3" spindles, Smooth-Rider leaf springs, and Doetsch Tech shock absorbers. Removing the "lip" from the LCA is very simple. Remove the factory bumpstop bracket, install low-profile units, and you'll be set.
Old 12-01-2003, 11:58 PM   #9
r0lf-
Hotwheels?
r0lf-'s Avatar
If you use the DJM spindles you will have to grind a bit of the spindle, not LCA to get 15" ralleys to work correctly, its really not a big deal though.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 12-02-2003, 12:04 AM   #10
BaggedC10
Under construction!
BaggedC10's Avatar
The spindle? I know some trucks will require the caliper to be shaved but the spindle?
I only had to remove the "lip" from around the balljoint.
Old 12-02-2003, 12:05 AM   #11
shavedchevy
shavedchevy's Avatar
I've got no problem with a 4/6 drop on my truck. I also have 235/60/15 and 275/60/15 on my truck like 78 chevystepside except I didn't have to modify anything at all on the front, no grinding, no weights. I've got 3" spindles from chassis tech and I didn't have modify them or the contolr arms. I also have no trouble turning sharp, actually I think it turns sharper for some reason.
Here's what level my truck sits at ...
shavedchevy is offline   Reply With Quote
Old 12-02-2003, 11:18 AM   #12
Slonaker
Slonaker's Avatar
Nice pics, 78chevstepside! The interference problems you are having are exactly what I'm trying to avoid. I'll give up 1/2 inch to avoid shaving calipers and control arms.
Does anyone else have any other vendors to suggest? I looked at the site for www.PerformanceSuspension.com. Their prices seem reasonable, so I'll give them a call. Sport Truck Direct doesn't seem to want my money, so I'll avoid them unless I just can't get what I want elsewhere.
Has anyone bought the Summit brand spindles? I like dealing with them, but I don't want to buy their spindles unless they are Western Chassis.
Will my 255/70/15 tires be okay on the front on Rally wheels with 2.5 inch spindles? Someone asked that this week on CT, but has not yet received a definite answer.
Thanks for the replies.
Slonaker
Stock '01 Silverado
