07-30-2019, 11:04 PM | #1 |
Wrinkled Inner Fenders
Need some advice. Is this normal? Can I fix it or should it be replaced?
I ordered new inner fenders from LMCTruck. The drivers side is slick, no issues. The passenger side has some crazy wrinkles in it. Is this normal? Can I fix this? Or should I have it replaced? Drivers side is fine.....
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
07-30-2019, 11:21 PM | #2 |
Re: Wrinkled Inner Fenders
I'm no expert but it seems like if one is smooth, they both should be. That wrinkled one looks pretty bad.
07-30-2019, 11:26 PM | #3 |
Worn out dies, and poor quality control. I think I would send it back with a picture of the good one so they know what your expectations are. Might save a lot of back and forth. I would give a call to customer service before sending it back. Might be ahead returning it and see if you can get a quality one from one of the board venders. I worked at a Navy rework facility and parts like that back in the day were formed with a drop hammer. When the dies were getting worn that is the type of part you would get. Although they may be done with some other method. now. Unacceptable.
Smitty '71 Short Fleetside Spring Valley, Ca. Last edited by Smitty; 07-30-2019 at 11:30 PM. Reason: Additional thought |
07-31-2019, 01:23 AM | #4 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-31-2019, 11:16 AM | #5 |
Almost Satisfied
My passenger had a couple wrinkles in it, but nothing like the pics above. I sanded it down and filled it with all metal.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
07-31-2019, 11:19 AM | #6 |
I would definitely send that one back. I have a rocker that looks similar unfortunately.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
07-31-2019, 12:23 PM | #7 |
Go Pack Go!
I wouldn't accept that. They may end up sending you a replacement and tell you to keep that one.
07-31-2019, 01:58 PM | #8 |
Thanks everyone. I called LMC and they are sending me a new one. And they are picking the damaged one up. Problem solved.
For anyone rebuilding their truck that is just starting plan in the future. That's something I have learned the most is ordering parts online no matter who it is has problems. UPS damaged parts in transit, lmc manufacturer sent bad part, brothers sent wrong part number, etc etc etc. So when you need something right away, and you jump to rockauto or Amazon for quick shipping, you still may not get it and your SOL...
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". Last edited by TA_C10; 07-31-2019 at 05:01 PM. |
07-31-2019, 04:59 PM | #9 |
Go Pack Go!
That's good news. I've dealt with LMC once back in 2003 and they were very responsive when I had an issue.
07-31-2019, 11:47 PM | #10 |
What does LMC stand for?
08-01-2019, 05:52 AM | #11 |
laying low
Long Motor Corporation
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
08-01-2019, 10:19 PM | #12 |
LMC lose my cash
08-02-2019, 02:15 PM | #13 |
Just got the call from LMC today and they called to tell me it's not cost efficient to pickup the bad fender so it looks like I'm stuck with it. Anybody want this thing?
08-02-2019, 02:33 PM | #14 |
Florida Edition
LMC is good for the little odd stuff nobody else has, not so much sheet metal.
Great catalog though.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
08-02-2019, 10:20 PM | #15 |
Who Changed This?
Ha! Put it in the recycle bin so it goes back to China for another try.
08-02-2019, 10:32 PM | #16 |
If I needed one, I would use it, but I don't need one. I hope someone will take advantage of your offer.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
08-03-2019, 12:06 PM | #17 |
If you paid for it on your credit card they will stuff it up their arse with a little coaxing.
08-03-2019, 12:32 PM | #18 |
BlahBlahBlah
It sounds like you are saying LMC is just saying keep it and not sticking you with having to purchase two. If that's the case I would hang on to it if you planning on building any more of these trucks. That side usually gets corroded because of battery leakage. You could probably use it to help repair one that has corrosion issues.
08-03-2019, 04:47 PM | #19 |
They are sending me a new replacement. I'm stuck with the wrinkled one because they don't want it back. I don't have room to keep it so I would rather just get rid of it. If someone pays shipping they can have it for that. Or if your local to DFW area come get it! Otherwise it's going up on FB Marketplace, those hounds will buy anything lol.
08-04-2019, 06:00 PM | #20 |
Any parts from LMC are going to be absolute garbage.
